Question about Jane Powertwin Azulon Stroller
Flat left rear tyre - Jane power twin
I have pumped it up a number of times and it seems to keep going down. Will it be damaged if I continue to us it and how can I fix t
  • Jyeman Jan 23, 2009
    my rear left back tyre is flat on my valco runabout delux pram i pump it up but it is flat again within minutes where can i get it repaired?
Think you have a puncture! tyre slime works wonders, i got a puncture on way home from school and used this repair system. worked a treat and treated all other tyres as a preventative measure. jope this helps
Posted on Nov 11, 2008
Jane Rider front wheel swivel problem....they get stuck.
We have had exactly the same problem. We took the pram back to where we purchased it from and got the pram fully serviced, the back tyres were changed for a better quality all terrain one, and the front tyres were also changed with new bearings fitted. It works as good as new now, however I still think this is only a temporary solution... Interestingly we have only used the pram (from new) for just four months before the tyres completely deteriorated and we found the manoeuvrability a major problem.
Jun 28, 2012 | Jane Rider Pushchair in Buganvila
How do you unfold the power twin frame?
The release is on the right hand side of the pushchair when you are holding the handle bar. It is about two thirds of the way down and is usually light grey with open written on it. Put Jane powertwin into U tube and KiddieCare do a video to demo this.
Jan 13, 2010 | Jane Powertwin Azulon Stroller
Zzr1100 when riding at very low speed steering is twitchy.
you need to check your tyre and it may also require balancing as it is a big bike.The bearing do not normally cause this but it is a good and safe thing to check it.
Nov 26, 2009 | 1994 kawasaki ZZR 1100
Flat tyre
If you have the "Mini Mobility System" your car has a tube of tyre sealant and an electric air pump. These are locate in the boot (trunk) under the carpet.
Shake the tube of sealant. Screw the filler hose onto the bottle. Unscrew the dust cap from the tyre valve. Unscrew the valve insert from the tyre valve using the screw device (very important). Push the tube of tube of sealant onto the tyre valve and hold the bottle with the cap pointing downwards. Squeeze the bottle and force the entire contents into the tyre. Replace the tyre valve insert using the screw tool (most important).
Get the electric pump and connect the hose with the pressure guage onto the tyre valve. Connect the pump electric plug into the cigarette socket in the car or power outlet in the boot (ignition key needs to be on position 1). Inflate the tyre to 1.8 - 2.5 bar. Switch the pump off for a moment to check the pressure accurately. Unscrew the compressor, and put everything away in the boot. IMMEDIATELY drive your car for about 10 minutes. This is to distribute the sealant throughout the tyre. Do not exceed 60km/h. After driving for 10 minutes, recheck the tyre pressures using the pump or at a service station. Continue your journey but keep below 80km/h until you have the tyre checked or replaced.
Oct 11, 2009 | 2002 Mini Cooper
I need an air pump for my jane power twin stroller
If you visit this link
you will be able to order a pump.
I hope this helps.
Oct 07, 2009 | Jane Powertwin Jogger
Hello, Our Jane Powertwin buggy has 3 flat tyres - they go down when inflated. From where can we buy new inner tubes please
You can get inner tubes at any bike store you just tell them what size they have all of them.
Jun 27, 2009 | Jane Powertwin Jogger
Run flat tyre warning light is on i have checked tyre pressure
This will only come on when a tyre has dropped in pressure (not spare). It work on the principle that a tyre with less air has a smaller rolling circumference and therefore a different wheel speed. This is then monitored against other signals from other wheels and determined that a loss in pressure has occured.
If all tyre pressures seem ok, there could be a chance of a small unoticeable leak and would require a bath test. This is when the tyre is dipped in water and bubbles would appear where the puncture is.
Ultimately the system may just need to be reset, or has incorrectly been reset from a tyre change. For this you just press and hold the TPC button (located on the centre console above the gearstick - looks like a flat tyre with an exclamation) turn on the ignition to position 2 and the light will come on re then yellow,go out, come back on yellow. When it comes back on yellow it re-initializing the system. You can let go of the button and after 20 odd seconds the light will go out for the final time, completing the reset.
If the light continues to come on after the reset then you definitely have a puncture somewhere!
Hope this helps!
May 28, 2009 | 2005 BMW 3 Series
Pulling to the right When pushing the powertwin it continually pulls to the right. It is extremely difficult to turn left with it. I have pumped up all the tyres but this does not help. This is a brand...
Check your tire pressure. We just experienced this a week ago. Sure enough, the right rear tire was flat. Once the tire was pumped up, it no longer pulled.
Mar 22, 2009 | Jane Powertwin Azulon Stroller
Broken wheel
I would suggest that you contact who will be able to put you in the right direction.
By the way, this sounds like you have a Powertrack Twin type pram.
I hope this helps.
Mar 17, 2009 | Baby Gear
Front tyre is flat..
I've had two flats on the back tyre on my jane power twin - the first time myself and my husband bought a tyre puncture kit and fixed it. The second time we tried the same thing but the puncture was in such an awkward position that the patch wouldn't adhere to the tyre so I needed a replacement. I went to my nearest Mothercare shop which sells the power twin and asked them to order me a new tyre. It took a week but the part came it and it wasn't just a tyre it was a whole back wheel. They charged me 10 euros (7 Stg approx). Hope this helps.
Dec 19, 2007 | Jane Powertwin Azulon Stroller
Jane Powertwin Azulon Stroller Logo
363 people viewed this question
Top Jane Baby Gear Experts
Shehu Pro
Shehu Pro
john h
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
