Question about RCA 27V530T 27" TV
Shows for one minute then goes tick, tick and shuts off
I recently bought a flyback and changed it. My TV shows for one minute and then makes a 'tick tick' sound and it shuts off. At first, this happened when i increased the volume. What could be the problem there? I purchased the flyback only about two weeks ago from Suburban Electronics on ebay.
  • 899 Answers
Ok try this , unplug the front control board , if it stays on then thats the problem , but if it don't , then you will need to check the components around the EEPROM and resolder all components that heat up, it is possible that the crystal and EEPROM may need to be replaced but doing these other things plus a couple of more checks will help find the culprit
also make sure all work is good, resolder and recheck are the best way to eliminate any problems
please give a fixya rating so that i may continue to help you if needed , thanks
electech
Posted on Nov 08, 2008
My computer shows no signs of powering up, but makes a ticking sound when the ac adaptor is plugged in
Try another Cord/charger first.( Beware of Cheap aftermarket cord/chargers/transformers!) The ticking , where is it comming from? Can you locate the origin of the ticking? The HDD, when it's bad, will try to spin-up and you will here a clicking/ticking. If the ticking is coming from the Cord/charger/transformer replace. I bought a spare, universal with plug adapters, for $50.00. Bad charger/transformers CAN be a fire hazzard, if left plug in unattended. Always unplug laptop when unattended, that is if you don't already.
Nov 22, 2012 | Toshiba Satellite L455DS5976 Notebook
Show for one minute then tick tick and shuts off
Check Regulator for 132V +-. Check for 32kv at CRT anode. Try lowering screen control on the flyback.
Nov 04, 2008 | RCA 27V530T 27" TV
My TV
the old ticking sound... yes.. it means your power supply shut down and continously trys to reboot ... hense the tick sound as the voltage rises and fails.
Means you got a short somewhere. Most likely the obvious high power consuming High Voltage Suppy... and as I found in 99.9 percent the Horizontal power Transistor shorted... 80 percent Flyback, 10 percent audio... 10 percent some odd circuits like vertical or yoke as shorted.
you have a short.
Sep 10, 2008 | Sanyo DS24424 24" TV
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
PROSCAN TV
Hi
the ticking sound is coming out from the flyback that is high voltages!!! if you on the unit is there a picture coming out? or sounds coming out from speaker?
Thanks!
Jul 02, 2008 | Televison & Video
RCA 27V530T Powers up and plays perfect for about 5 min then shuts off
look for cold solder joints on primary side of power supply
Jul 01, 2008 | RCA 27V530T 27" TV
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
TV making ticking sound when turned on
most times I hear that ticking its the high voltage failure ...most likely a shorted HOT fallowed by flyback. the ticking is your shut-down engaged.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
RCA 27V530T 27" TV Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
