Question about Video Game Consoles & Games
Wii Remotes will not charge - Red light shows all the time and never goes green. When you want to use remotes they have no charge. The Wii console works fine in the power station. Any ideas please as to what may be wrong?
  • Glyn the Pin Nov 04, 2008
    Thank you for trying to help. However I have a confession to make! Although the help didn't have any effect on my problem I decided to re read the very bad instructions and try again by switching Wii on to see what happened. It appears some charge had happened and the red light changed to green when remote removed from powerstation. Then late last night I noticed the lefthand remote light has gone green. So being a bit of a 'girl' I assume we just had to wait longer! Having said all this the morale of the story is to not believe everything you read i.e. instructions and just be patient. Thanks.
    Problem Solver:
  • 15 Answers
Are you using a base station e.g. made by 4gamers?
- If so, as it has a battery slot at the back as well as the slots for the controllers, it may be set to charge this not the controllers, there is a switch on the back.
- Ensure correct batteries being used in remotes (NIMH).
- There are multiple lights on the station and there should be a light next to the remote station you want to charge. If this is not lit, see if there is a switch, if not then was there a special battery back for remote provided by the charging station? As some need ot to transmitt the power to the batteries through a strand of metal.
Posted on Nov 03, 2008
If the wii remotes aren't working, responding, or charging, can the remotes be reset or do I need new batteries?
First you will meed 2 try new batteries then you will need to press the 'Red' button
located on the Wii console to 'Re-tune' in the Controllers
How to Sync the Wii Remote Standard Mode Wii and Wii mini Nintendo...
May 11, 2014 | Video Game Consoles & Games
Tip
How to snychronize a Wii Remote to the Wii console
A lot of people have trouble synchronizing their Wii Remotes to their Wii console. I have written a short tutorial on how to do this.<br /><br />Figure out which scenario is similar to yours and proceed with the solution-<br /><br />1) When you turn on the Wii console and press any button on the remote no lights light up at all. This is because the remote is dead, you must replace the batteries in the battery compartment on the underside of the remote. If the controller is using a charge pack you need to put the controller on its charger.<br /><br />2) When you turn on the Wii console and press a button on the controller all four lights blink a couple times then turn off. This means the controller is not synchronized. If your controller has ever been previously synchronized all you need to do is press the 1 and 2 buttons at the same time and it will sync up.<br /><br />3) If option 2 doesn't work then this means you are preforming a first time synchronization with the remote. While the Wii console is turned on you should open the little compartment that is just below the disc tray. Then you should press the little red button. After pressing the red button you should open your Wii Remotes battery compartment, remove the batteries and press a similar little red button inside of the compartment. Put the batteries back into the controller and the controller should be synchronized! <br /><br />If none of these solutions are working then the problem is a technical issue with either the Wii remote or the Wii system, you should contact technical support for more information.<br /><br />I hope this helped with the synchronization of Wii Remotes!<br />
on May 16, 2011 | Nintendo Wiimote & Nunchuk Controller...
How do I synce wii remotes
instructions
  1. You will first need to make sure your Wii remotes have batteries. Then, turn on your Wii and go to the Wii menu.
  2. Open the little white door on the front of the Wii game console (this may require using your fingernail). You will notice a little rectangular red button.
  3. Open the battery compartment of your Wii controller, which may require removing the rubber jacket. You will notice a little round red button there.
  4. Press and hold the red button on the Wii game system and the red button on the Wii remote at the same time for at least 2 seconds. I usually hold down the remote button, then press the game console button for 2 seconds because it is easier for me. You will notice the 4 little blue lights on the front of the controller blink many times. The lights will eventually stop blinking and one of the four lights will remain on. The light that remains on tells which number Wii remote you have. The one on the left is number 1. The second from the left is number 2, etc.
If you bring your remotes to a friend's house to play, don't forget to sync your remotes back to your Wii console when you get home.
All the best!
Tsunami Dan
Read more: HERE
Mar 29, 2011 | Video Game Consoles & Games
Light mode on console itself
you do have rechargeable remotes right? And the light only goes to red if you are not connected to the internet or were connected but unplugged it. i use a store bought charger that came with a rechargeable battery panel that plugs into the remote. so if i take the battery cover off the batteries are attached to it. but that is just me i don't know about you. hope i helped. If i didn't, post a new problem that tells the steps that you take to try to charge them.
Jul 22, 2010 | Nintendo Wii Console
We do not know how to charge the remotes for the Wii using the competition pro charger. We place the remotes on the base but the blue lights on the side aren't illuminated and the charge doesn't transfer...
the batteries in your wii remote..... are they rechargeable batteries??? if so then there could be a malfunction withing your comptetition pro charger.... however if they arent rechargeable.... try putting rechargeable batteries in the wii remotes!
Feb 17, 2010 | Video Game Consoles & Games
Wii controllers not working, new batteries, but will not move on screen...
You need to synchronise the remotes. Take off the battery covers on the wii remotes and open up the flap on the front of the wii where you can put a memory card in. Press the red button that is above the memory card slot and at the same time press the red button that is above where the batteries go on each remote. The wii remotes should flash and eventually give a solid light on either the first or second led at the bottom of the wii remotes. When this happens both remotes are synced.
Dec 29, 2009 | Nintendo Wii Console
Wii remotes will not charge in the charging station
your wii remotes might have a shortage in them....i advise you to buy new or used remotes
Oct 02, 2009 | Nintendo Wii Console
Remotes can't be found
When you change the batteries for a Wii Remote (in my experience) you have to re-sync (reconnect) them to the Wii console. To do this, there is a button on the Wii Remote by the batteries that either says sync or will show curved bars on I think i red button. This same button should be located on the Wii console. You have to push the sync button on the Wii then on the remote to sync them together. This should solve your connection problem.
Apr 29, 2009 | Nintendo Wii Console
Remotes don't work
on the battery pack of the remote there is a red button that says sync and there is a red button on the console by the sd card port press both of the buttons at the same time and it will work.
Mar 07, 2009 | Nintendo Wii Console
Wii remotes cant get synchronized
Press the red button near the SD card slot then press the red button undre the Wii remote's battery cover to synchronize again.
Feb 28, 2009 | Nintendo Wii Console
Video Game Consoles & Games Logo
153 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
