Question about SAMTRON 55V 15" CRT Monitor
Want tips on factory modes
How to enter factory modes for adjest white balance in SAMTRON, LG,viewsonic and PHILIPS monitors
Tip
SERVICE MODE AND SCHEMATIC DIAGRAM
NOBLEX 29TC656F
White balance adjustment Mode - Be used for White balance adjustment. In Factory Mode, press" BUS OFF" to enter and exit.
Default Value OK mode - Be used for default value setting before TV leaves Factory. In Factory Mode, press "S. EFFECT" to enter default value. "Wait" will be displayed in screen, when it is finished, "OK" will be displayed. It will exit factory mode automatically.
Note: Now press "SERVICE" cannot enter factory mode, you have to take the following steps to enter:
1. Setting Volume to Zero.
2. Press "V-" in cabinet and Press "Display" in RC simultaneously
Adjustment Way1. B+ Adjustment:
Apply Philips Test pattern signal in normal status, adjusting VR821 to make B+= 130V± 0.5V.2. RF AGC adjustment:
Observe monitor the collector waveform of Q101 with the probe of Oscilloscope. Select channel 2 (>70dB) from the antenna input. Enter D-mode, select menu6 to adjust RFAGC item until the monitor peak value to 0.8Vp-p.
TO KNOW MORE CHECK THE LINK BELLOW
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 18, 2015 | South Shore Noble 60 TV Stand - -
Osd problem
Try turning the power off, press down the contrast and britness setting bottons and turn the monitor back on and release the buttons.
Next if that dosent work try holding the menu button down until you get osd unlocked come up.
Hope this helps.
Feb 04, 2010 | HP w1907 LCD Monitor
LG Flatiron monitors.1st one on Dell pc works great. 2nd one in same household to Compaq pc still flashes faint pink on parts that should be white.
Probably just some color balance is of. Reset white to something different on the compaq. Try downloading nvidia-settings and see what happens when you mess with color balances. Mess around with some settings til it looks right, or see if you can reset the white balance to a different preset on the monitor's menu
Oct 26, 2009 | LG L1920P 19" LCD Monitor
Viewsonic Monitor and the text is not black but grey.
try to log in safe mode and reinstall the display adaptors or uninstall them and reboot
Feb 01, 2009 | ViewSonic G90fb 19" CRT Monitor
Samton56V white balance alignment
first you adjust eht screen voltage and focus control
Jan 13, 2009 | SAMTRON 55V 15" CRT Monitor
Horizontal width problem
1. change the flyback 1600v working voltage pf.(near to Horizontel transistor.)
Dec 10, 2008 | SAMTRON 55V 15" CRT Monitor
M2N-MX SE Will Samtron 55V work?
Does not matter the monitor, has to work , probably u test it on a resolution or frecvency that u're display does not support, try to enter safe mode (for windows) by pressing F8 on boot up , and chose than safe mode, or VGA compatible mode, should work! Change the resolution/freqvency to one that u're display supports
If u have more than one video adapters (one onbord) try to see whitch one is enabled....
Jan 16, 2008 | ASUS M2N-MX Motherboard
SAMTRON 55V 15" CRT Monitor Logo
98 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
