I left my fujitsu siemens laptop on charge and when i tried to turn it on it wouldnt come on, no lights, nothing. it refused to boot up, the battery is discharged, what can i do to solve this problem plz? thnx
could be hard drive failure,or you might try to reinstall windows before bying a new hardrive,but before any of that go to the BIOS and make sure that the boot order is right usualy hard drive first
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Hi, No that not normal. Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off. Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop. If the light comes on then it's charging. If it doesn't then there is a problem with the laptop. I would recommend giving Fujitsu a call as their customer service is excellent.
hi i have fujitsu sieman amilo 3710 it will no switch on there nothing no noise no light but when put it on charge the little charging light comes on to say its charging can u help
Completely drain the battery so the computer wont even switch on and charge it over night. If its still not working after that then you need to get a new battery.
it seems that before shutdown system was updating pc (in all cases) windows update does this in silent mode so sometimes youre not to know.
boot up as normal...wiat a minute or so ...press and hold power button until pc shuts down completly(you can hear this) a light should be lit momenterily and then fade off.
you may now be able to reboot.
Hi if you had not used your notebook for sometime and kept it without charging the batt., then charge the batt fully probably for 12 or 14 hours and then switch it on .
