Question about Dewalt D25900k Heavy Duty Demolition Hammer Breaker
Ground rod driver
Sizes types and Mfg. of Ground Rod Driver that fit D25900 Type 2 Demolition Hammer
  • 550 Answers
PGD 97-0603-625 (for 5/8" rod)
PGD 97-0603-750 (for 3/4" rod)
Driveze Corp.
30 Possum Circle
Norwalk, CT 06854
Tel: (800) 448-2912
Tel: (203) 853-7698
Fax: (203) 853-6317
www.drivezecorp.com
Posted on Nov 03, 2008
Comes on will not jack hammer
If your motor is working but you aren't getting the hammer action you likely have a broken connecting rod (PN 1612001033). Everything in the impact mechanism housing is made of hardened steel except the con-rod, it's plastic and notorious for breaking. If you go into the mechanism to verify the part is broken keep track of where and how everything goes together, there are a lot of parts in there. If you go to http://www.ereplacementparts.com/ and search for your model number you will get a good breakdown of your demo hammer, the con-rod is item #70. You can order parts from them or use the part number to search the web.
Nov 10, 2011 | Bosch 11316evs Elec Vs Sdsmax Demolition...
How do you remove the front hub to remove the stuck nail
If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
Nov 01, 2011 | Stanley Bostitch F21PL Nailer
This demolition hammer will make the sound like is rotating inside to do the hammering motion, but the shank doesn't do anything at all. what could cause this problem? Thanks.
Large hammers have an air driven piston (an air cushion betweem pistons) and an intermediate anvil that actually hammers on bit. If the cylinder and air cushion piston are dry there will not be enough suction/pressure between the driver piston and driven. Remove lower part of hammer and lube with electric hammer grease. Make sure that orings fit snuggly and the anvil is not jammed. Do not store hammer with the bit pointing up because the driven piston will slide down cylinder and hug driver piston. If the hammer was stored pointing up, turn hammer around and place in stand with nose down in a warm location so that the driver piston will drop into place. Good holidays
Dec 17, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Will this drive half inch rebar through 12 or more inches of landscape timber in a retaining wall?
Yes, but I usually drill a hole just a bit smaller then the rod so that the rod does not split the landscape timbers....
You can buy ship auger bits up to 12" long and they drill through the landscape timber fairly well...
heatman101
Nov 22, 2010 | Bosch HS1924 Sds - Max Hammer Steel Ground...
8 penny nails are stuck in gun. How do you get them out?
If the nails are stuck in the rails, remove the rails and fish them out. If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
May 03, 2010 | Dewalt D51844 Framing Nailer
Where do I fit an earthing spike and how..?
As close to the service entrance as possible. That is to say, where your exterior electric panel is. If the ground is soft enough, you can use a sledge hammer or single-jack (3lb/1.4kg hammer) and a ladder to pound it in. If the ground is hard, trickle water on the spot to use overnight to make it easier and get an electric demo hammer with a rod-driving bit to drive it in for you. You can rent these at larger home improvement stores. Make sure you have a friend or two to help as you will be up a ladder with a pretty heavy and ungainly tool for this job. Once the ground rod (earthing spike) is all but a few inches into the ground, use an approved rod clamp to bond your ground (earth) wire and then install in the panel.
i hope this helps,
matthew
Nov 18, 2009 | Electrical Supplies
Colorgraphic LT 4 need driver for Vista
GO ON LINE AND TYPE THE FOLLOWING IUNFORMATION:
COLORGRAPHICS LT 4 DRIVERS
OR
COLORGRAPHIC PREDATOR LT4 DRIVERS
OR
MFG NAME,MAKE,MODEL.COM
ROD
Feb 19, 2009 | Color Graphics PREDATOR LT4, (16 MB)...
Download ati 3d rage lp pro drivers
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
ATI 3D RAGE II DRIVERS
WWW.ATITECH.COM IS THE MFG IN MY BOOK
WWW.WINDRIVERS.COM
WWW.DRIVERSHQ.COM
ROD
Jan 12, 2009 | ATI 3D Rage II, (2 MB) Graphic Card
Dewalt D25900k Heavy Duty Demolition Hammer Breaker Logo
363 people viewed this question
Top Dewalt Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
richie46
Are you a Dewalt Hammering Expert? Answer questions, earn points and help others
