No Sound From Power Amp
I have a Carlsbro Powerline Series 300W power amp which powers up, but produces no sound except when I turn the volumes up full, and then only for brief moments.
  • 2 more comments
  • neildono Nov 04, 2008
    Thanks. The amp was working fine the week before. I was using in in a DJ setup at about half volume. I'm wondering if something has popped?
    I don't think it's the volume pots as it was working before OK.
  • neildono Nov 06, 2008
    Anybody had experience of this problem?
    Thanks Robotek, it's being driven by a mixing desk which I know is OK, as I've routed it to a different amp and it's fine.
    The shorted speaker/ lead/ plug might be a cause. The whole setup was moved before it went wrong.
    Could a single speaker short make the whole thing go wrong?
  • 728 Answers
A fuse may have blown or you might have a short that is preventing it from coming on at low volumes. You will need to get it checked by a professional to get it fixed.
Posted on Nov 06, 2008
  • 19,396 Answers
That means that the pre am is gone, get schematics and test the board.
Posted on Nov 04, 2008
  • Ginko
    Ginko Nov 06, 2008
    Not only a single speaker short can make the whole thing go wrong, with a little back luck a shorted speaker acn burn a amp final.
    Master:
  • 505 Answers
As you said you have to increase the volume to get the sound so we can be sure that the cables on the back is connected properly.
The solution is replacement of all four output transistors. The ones mounted on the heatsinks. They must be replaced with ones that are the same case size and pin configuration and a higher voltage and current rating than the originals would help it survive the future.
This means that you need to get the ampplifier repaired by some technician.
Thanks
  • Indrajit Roy
    Indrajit Roy Nov 04, 2008
    Check the back of the amplifier which connects the cable for the speaker and see if its set properly
    Thnaks
  • Indrajit Roy
    As posted by sweet_rascal, it is not require to unplug the speaker because amplifier doesnt have any inbuilt speaker.
    Thanks
    Guru:
  • 1,894 Answers
Have you checked the speakers with other amplifiers?
if not please check
  • dewan nafees ahmed Nov 04, 2008
    cool invention by Bappa170873 that amplifier has no inbuilt speakers. shows clearly the lack of proper English understanding.
    i have said you to check the speakers by using them with other amplifiers which are working fine. use them from your friends. so that you can sort out the problem.
    if it is with the amplifiers let me know i shall guide you what can we do next. if it is with the speakers then there is nothing we can do much about that.
    but what i doubt is the switch which you use to increase the sound. that must be the real culprit in this case if amplifiers are found guilty.
    Brigadier General:
  • 6,966 Answers
If your model uses the twin rotary volume control, then it would possibly be the wiper arm of these controls are not touching the carbon. In effect these are variable resistors. A quick temporary workaround is to open the unit and spray the inside of the volume controls with electronic contact cleaner. However, as stated a temporary workaround. Of course the correct procedure would be to replace them.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
  • 1,512 Answers
Hi, a couple of questions,
  1. do you have any indicator lights coming up.
  2. are levels and audio quality normal when the amp does come up?
  3. what are you driving the amp with and is it ok?
Get back with a comment and we shall see if we can get to the bottom of the problem for you.
regards
robotek
  • 2 more comments
  • Graeme Ross
    Graeme Ross Nov 04, 2008
    If you hear a click coming from the internals of the amp, associated with the amp cutting off this is the protection circuit operating. It may well have an indicator on the front panel showing that protection mode is deployed. This indicates that there is a fault in the amp, or one(both) the speakers or cabling to them. How things actually sound will help to diagnose past this
  • Graeme Ross
    In normal operation, the best way to run the rig is to have the level controls on the front of the amp power turned all the way up, you then have an accurate metering of the levels you are working with on the mixer console from the master VU meters, then of course using the master level to control the desired volume.
    If you have a multimeter, a way of checking to see if you have a shorted speaker/lead/plug is to check each of them from the speaker leads at the back of the amp with an ohms meter. You should not measure less than the rated impedance of the speaker that it is attached to.
    You can also do a check by going about a listen to each box(your ear up close to the drivers so no mistake is made about what is working and not) and determine that all speaker drivers are working correctly.... High Frequency and low frequency. All it takes sometimes is a 1 faulty driver and the amp may shut down.
    Can you do these checks and report back.
  • Graeme Ross
    Graeme Ross Nov 06, 2008
    Yes, a shorted speaker wire may well be causing the problem. If not sorted out could also damage the amp. Some amps have one relay that will shut down both channels when a fault condition is present. If things have been moved, it is worth going over the length of the cables looking for damage, or inside any connectors used to be sure there are no short circuits or stray strands of wire shorting out. Check at the back of each speaker also. Check also that the amp has not had any settings on the rear bumped out of position, specifically bridge/stereo mode. You could use a multi meter to check for short circuits also.
    USE VERY LOW LEVELS TO TEST SUSPECT SPEAKERS WITH AN AMPLIFIER.
    You run the risk of damaging the amplifier in doing so at higher levels. Important to remember that shutting down/low audio levels means there is a fault somewhere.
  • Graeme Ross
    so do I get the ACCEPT :) Happy to advise you further.
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
I have a sound stream xta 600.2 what would be the best 12" subs to with it
match your total rms output at the resistance you will be running the amp at to the subs.
example:
if your amp puts out 300w RMS@ 4ohms, then it will produce 600w RMS@ 2ohms. half the resistance, double the power.
So now that you know your available power, you should get speakers that will be used to the fullest at that given resistance.
example:
If you have two 4 ohm subs that have a power handling of 300 watts, Then you can wire them in parallel ( + to + and - to -) to get a 2 ohm load (which will be 300w per sub with the above amp) or in series (+ to - to + to -) to get an 8 ohm load. (300w amp @ 4ohms = 150w amp @8ohms = 75 per sub).
Keep in mind: choose the speakers to fit the amp, not the amp to fit the speakers. If the amp has more power than the speakers can handle, you will blow them. and ALWAYS USE RMS WATTAGES.
May 06, 2011 | Soundstream Xstream XTA600.2 Car Audio...
Volume at 10 produces very low speaker output.!?
It sounds to me that all you are getting is the pre-amp stage of the amp and nothing from the power amp stage. As it is on both channels then it is something that is common to both. This could be something to do with the power supply of the power stage. Or whatever is on the heatsink. It could be that the amp uses a single audio amp IC for both channels. If it does my bet is that it's gone. If it uses two sets of semiconductors for the right & left channel it would be highly unlikely that both channels have gone, but not impossible.
Dec 27, 2009 | Audio Players & Recorders
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
Dec 16, 2009 | Yamaha P-2500 Amplifier
Power lite on, no sound from amp after 1hr of usage
HI DUDE UR REMOTE WIRE FUSE IS BURNT .... REPLACE IT ... AND UR SPEAKER ... OR SUB TAKES LOT POWER FROM AMP .... ....
Apr 17, 2009 | Kenwood KAC-428S Car Audio Amplifier
Subwoofers pop then immediately produce no sound
Sounds like the two subs wired together might be too much of a load on the amp and it is shutting off. Try wiring the two subs in series. That will reduce the load on the amp but will conversely put out less power. Less is better than none though. In any case check your amp to see what the lowest ohm rating it can see, that ohm rating is where you want your subs and if faced with a choice of either going under (lower numerically) or over (higher numerically) GO OVER!-it is much safer.
Here's an article I wrote that can help explain how to wire the subs to the amp.
OHM LOADS, SUB WIRING, OHM RELATED POWER OUTPUT
SERIES SUBWOOFER WIRING
Wire the positive pole from one voice coil (using wire that is as thick or thicker than your wire from amp to sub) to the negative pole of the other voice coil (on the same sub). This will leave you with a positive pole from one voice coil and a negative pole from the other giving you the two leads that will be hooked up to the amplifier or other subs. When wiring in series, the ohms will go up numerically, and the load on the amp will go down. Almost all amplifiers power output will follow this rule, except some amps such as JL Audio's “Ohm matching” D Class amps.
PARALLEL SUBWOOFER WIRING
Wire the positive pole from one voice coil (using wire that is as thick or thicker than your wire from amp to sub) to the positive pole of the other voice coil (on the same sub). Then wire the negative to the negative in the same way. You can then wire to the amp or other subs. When wiring in parallel the ohms will go down numerically, and the load on the amp will go up. Almost all amplifiers power output will follow this rule, except some amps such as JL Audio's “Ohm matching” D Class amps.
MULTIPLE SUBS USING SERIES AND PARALLEL WIRING
In order to match your amplifiers ohm rating you can use parallel and series wiring together, just keep things even for power distribution and to avoid phase issues.
Example: I have two “Type X 12” subs” that have dual 2ohm voice coils and have to match my “Amplifier X” ohm rating of 2ohms mono. In this case, I would wire each subwoofer in series (giving me a 4ohm load), and then wire the two subs in parallel to get my 2ohm mono load. When wiring multiple subs just, treat each sub as a voice coil and wire accordingly.
POWER OUTPUT AND OHM LOADS
For example if “Amplifier X” can make 100watts@8ohms, it would make 200watts@4ohms and 400watts@2ohms. However with every drop in ohms the amplifier is put under more pressure. It starts to create a lot of heat, distortion figures begin to climb, damping rates drop, and some amps even throw power spikes when clipping. SO BE SURE TO CHECK YOUR AMPS RATING AND DO NOT EXCEED IT!
-Dynami
Apr 04, 2009 | Alpine Car Audio & Video
Xtant 3300x
It sounds like it's going into protection mode.
Do any of the channels pop when it's switching on and off?
If you power it up via a single 15 amp fuse (in series with the B+ line), does it blow the fuse when it powers up?
Sep 16, 2008 | Car Audio & Video
PA amp + speakers
remove every sound input one by one until you find the one who make the trouble.if this procedure failed sent it to sevice center to fix it.
Oct 17, 2007 | Audio Players & Recorders
My Emerson NR305TT will not produce sound. Turn table works, CD Player works, FM Tuner Works, everything works except no sound comes from the unit. The on switch and volume seem to work as I hear a faint...
You have one of 3 problems:1) bad solder joints in the amplifier or preamp section 2)defective output transistors/ICs in the power amp or 3)missing or incorrect voltages to the amp section. If the unit has a headphone jack plug in a headset. If you have sound then everything is OK thru the preamp section and your problem is in the power amp. Any competent repair shop should be able to solve this one easily.
Jun 19, 2006 | Emerson NR305TT CD Shelf System
63 people viewed this question
 Grubhead
Grubhead
