Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Fisher paykei dd603 double draw f1 falt showing
I am house sitting for a friend and the dish washer is flashing f1 , i have no manual so have no idea what to look for , any help out there please.
  • SB in Austin Feb 12, 2009
    I had the same problem with my Fisher & Paykel DD603 SS dishwasher. As the manual suggests, my technician told me to turn the water and power supply off to the dishwasher. This is to prevent any possible further water damage to the unit and your home. According to several internet posts and authorized servicers, the F1 falt is a common problem for the older units (2005 and prior years?) caused by various faults such as an obstructed drain and the more expensive unit leak/flood failure.
    My technician first checked for any obstruction in the water pipes/drains. After confirming the pipes and drains were clear he examined the unit. He believes there is a water leak with the actuators and/or diaphagm. Per my technician, a kit would likely need to be installed to remedy the situation. F&P has an upgrade kit that includes:
    • 528112 & 528113 Upper and lower lid actuators
    • 528437 Link Support Retrofit kits (one for each drawer)
    • 529849P Mains Filter Board with updated cover
    Costs approximately $225 plus labor. I think I am going to try this to fix the problem.
    Has anyone had success using this repair kit? I hope you found my posts helpful. Any thoughts/experiences on the matter would be appreciated.
    Thank you!
  • 125 Answers
SOURCE: Fisher& Paykel
Its under the bottom drawer dry out and re-assemble
Posted on Jan 12, 2008
Master_Tech
  • 770 Answers
SOURCE: dish drawer by fisher and paykel DD603 FPZW
flooded unit please remove drawer abnd dry board also read some of my other post on this problem
Posted on Aug 05, 2008
  • 3 Answers
See also http://www.fixya.com/support/t346941-f1_error_1_draw_dishwasher
Posted on Nov 03, 2008
vitg55
  • 78 Answers
SOURCE: Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Posted on Dec 01, 2008
  • 11 Answers
SOURCE: Dish draw DD603 showing F1 error and spanner -
software error, check it out through sompany exper repairer
Posted on Aug 07, 2009
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Error E1
there is no e 1 error in dd603 , maybe u1 or f1 , u can call 1800650590 nd ask hem to send the use nd care manual , or download it from fnd p website ,
If it is U1 its saying taps not turned on , more than likey u have a F1 fault which is a flood sensor error , which means u need a new mains filter board around $50 to buy
Jan 31, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a dish drawer DD603 purchased in 2005. It
I presume you have a double drawer model.
Does this problem occur with both drawers?
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Th dish washer that we have is the 2draw dd-603m
A lot depends on how it happened. Is this a new installation or everything was working well until now? F1 error implies the float switch in the drawers is activated as the inlet water soneloid could not turn off. This prevents the units from being flooded.
Are you using the correct pressure setting for the water supply. Check the user manual for details. IF you don't have one, download from the fisher & paykel website.
Nov 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
With a DD603 d/washer , the F1 sign flicks once the w/cycle ends
F1 is a fault that occours when a waterleak is detected if oyou rmeoveth elower drawe there shoudl be a trouble shooting guide taped to teh back wall inside,very helpful
Jan 25, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish drawer by fisher and paykel DD603 FPZW
Jul 19, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
264 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
