Question about Olympus Stylus 710 Digital Camera
Battery charger flashing red light
I have an Olympus Mju 700 that I haven't used for 3 months. Yesterday, I switched it on and the battery was low so I put it in the charger. For about 30 seconds, the light indicator on the charger was steady red as normal when charging. However, the red light starts blinking instead of being steady. I thought it might be because the battery was very low, so I left it overnight but til this morning, the red light is still blinking. Any ideas? Thanks in advance.
Laura.
  • gr8prasu Feb 09, 2009
    Exactly Same problem, did you get some solution for that ? Please share ...
  • Big-D Aug 28, 2014
    Take the battery out and put it back in sme times you have to do this several times till the red light stays on also clean all connections I get the same problem but in the end red light stop flashing stays red till charged then green when full hope this helps
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Posted on Jun 23, 2009
  • ohwhite
    ohwhite Aug 05, 2012
    Is there a substitute to rubbing alcohol please? Thanks
Hi, there I have the same problem as well. I read somewhere on this website that there is someone else who had the same problem which was a case of wrong battery, since she acquired that battery from ebay. Upon purchasing the battery from the right seller, she is able to charge it.
However, since my battery was acquired from the right seller, I dont see why my battery cannot be charged, so i called the call center, and the guy told me to clean up my battery charger (the area where the battery meets the charger. It works, so you guys can try too.
Posted on Mar 10, 2009
    Problem Solver:
  • 19 Answers
Clean the points on the charger and on the battery and the red light will stop flashing and stay on constant red till the battery is fully charged
Posted on Feb 23, 2010
Cleaning the contacts on my charger worked for me - thanks all!
Posted on May 22, 2011
  • 4 Answers
HIf the charger is flashing red then the battery was allowed to fully discharge. You can either buy a new battery or force the charger to charge the battery. The way you do this is by applying a voltage across the charging terminals while inserting the battery. I opened the case of my charger and attached wires from a AAA battery to the corresponding wires attached to the charging deck (+ to red and - to black). Then I slipped the battery into the charger and plugged the charger into tho wall. The light should illuminate solid red (no flashing). Then immediately (and carefully) remove the wires from the charger.
Posted on May 27, 2009
SOURCE:
Although the manuals nothing says about flashing red light on charger, my best guess is the battery is defect.
Try to remove the battery several times and start the charging again and again. But when after a few attempts the LED starts flashing again, you better buy a new battery. When you don't use the camera for a longer period, make it a habit, to charge the battery every 3 months or so.
Jan 13, 2014 | Olympus Stylus 850SW Digital Camera
Olympus Tough-8000 Flash Charging Warning
It could be the capacitor in the flash is defect, but it also could be your battery (batteries) are to low on voltage. ALthough when that happens the camera should switch of.
There could be all other kinds of defects, like oxidation of some contacts or a broken flat cable in the camera, But my guess is the capacitor does not charge to the correct voltage.
Dec 08, 2013 | Olympus Mju Tough 8000 Compact Digital...
Olympus u770 sw 7.1 No power, battery fully charged, lens cover is open. No lights no screen nothing. Camera has been perfect for almost 4 years just shut down whilst being used hence lens cover open. Any...
Hi
Sorry to hear about your issue with the Olympus mju 770 SW. There's a couple of things you can check and try, before thinking about a repair or binning the camera and getting a new model.
1. Check the contacts on the battery are clean?
2. Clean the contacts inside the cameras battery compartment are clean?
3. Is the charger actually charging the battery? Try another battery or see if you can test the existing battery with a multi-meter to check there is some power in it.
It is fairly common for chargers to fail, so it's worth checking out but don't go spending money on a new charger unless you know it will fix your problem.
Hope this helps
David
Jan 13, 2011 | Olympus Stylus 770 SW Digital Camera
My battery died and i lost my charger so i bought a universal charger and it says the battery is fully charged, but when i put it in my camera wont turn on at all, a little red light flashes when i hit the...
dear sir,
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
if still the problem is the same ,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest olympus service centre and it is going to be done free of cost,as your camera is under warranty .......
thank you...take care
thank you.....take care................
Oct 08, 2010 | Olympus Camedia C-350 Digital Camera
I have an Plympus Stylus 1040. is the battery charger supposed to blink while charging?
Yes, you are right.
The charge indicator light will keep flashing till the battery is fully charged.
Sep 11, 2010 | Olympus Stylus / mju 1040 Digital Camera
My Olympus Tough 8000 charges up to a blue light but when I unplug the charger and switch it on, it just beeps multiple times and switches straight off. I've only used it for a week and it's a new,...
i have the same problem too. Mine is mju tough 6010 and it just beeps and switch off. The metal cover in front of the lens won't open. Mine is just 1 month old.
Aug 27, 2010 | Olympus Mju Tough 8000 Compact Digital...
Battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
Feb 15, 2010 | Olympus Mju Tough 8000 Compact Digital...
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
When i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Jun 11, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Battery doesnt charge!
well if it´s new.... just go to a olympus dealer and ask them to exchange it
Apr 02, 2007 | Olympus Stylus 700 / 700 Digital Camera
Olympus Stylus 710 Digital Camera Logo
10,304 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
