Question about Philips DVDR75 DVD Recorder
Need region free code for philips DVDR 3600
Hi
Like to make my dvd player recorder region free
4 Suggested Answers
  • 153 Answers
SOURCE: hi, do u know a
1. Press SETUP on the remote
2. Press 5 0 1 8 and Pick Region-code from 0-6 (0=Region Free)
Posted on Jul 17, 2011
Testimonial: "in fact the solution is the same I saw on a blog on internet , a few days after I left this question, i'ts cheering me up , it confims the solution."
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
BElectric
  • 1140 Answers
SOURCE: Can you please tell me
These are the instructions for changing the DVDR3380 to region free:
1. Remove any disc from the player
2. Switch the power off
3. Power back on again
4. From the remote enter 0 - 0 - 0 - 9 - OK (The player should display the current region code)
5. Open and close the disc drawer
6. From the remote enter 0 - 0 - 8 - 6 - 0 - 0 - 0 - OK
7. Open and close the disc drawer again
The DVD player should now be region free. It's usually a good idea to switch the power off and back on after entering region codes to make sure they have been stored.
Please note that not all region hacks work with different firmware versions and sometimes the code entry is different depending on which region the player was originally set for.
Please let me know if this code worked for you.
Regards,
BElectric
Posted on Dec 18, 2010
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
Making Philips dvdr 3600 region free
press SETUP on the remote and then press this code: 5 0 1 8 ,now you can pick Region-code with the remote from 0-6
( 0=Regionfree)
Aug 03, 2008 | Philips LX3600D System
Code for remote control of philips DVDR 3360D Hard disk / DVD Recorder
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Apr 15, 2008 | Philips DVDR 3355 DVD Recorder
Philips dvdr 3320 v DVD Player Unlock region codes
Mar 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Code required please
hello .
try this region codes for the region codes . for philips dvdr 3380.
riz.
Feb 09, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd player
i need remote codes for philips 734 dvd player
Feb 02, 2008 | Philips DVDR 3355 DVD Recorder
Philips DVDR75 DVD Recorder Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
