Question about HTC G1
G1 Phone Wont Charge
My g1 phone wont charge, I plug it in the power supply, but it doesn't charge.
Is this a common problem?
  • 113 Answers
take the batteries out and put it back in again and try charging check in diff power sockets press the end of the charging cables with little amount of pressure and have a check try to connect via the usb cable to the computer and check if it charges, if works the charger is faulty if still did not work then it will be firmware problem with of phone
Posted on Nov 03, 2008
My iphone 4 8GB only charges when powered off. It doesnt show charging symbol and wont charge while powered on. Not jailbroken. Itunes doesn't recongnize it while plugged in to laptop I tried 4 di
First, make sure that if your iTunes version is high enough to fit the version of your iPhone.
About charging, I think it means the output current of your charger is to low to charge and run your iPhone at the same time. This case is most like that, when a iPad 2 link to PC it won't charge when the scree is on.
If you are using digital products frequently, you can try to get a dual USB output external power supple, which hold on 2 type of output current 1A for common cell phone, 2.1 A for iPad, Pad PC and some device which need high charge current
Apr 03, 2013 | Apple iPhone Smartphone
Phone won't come on
my name is Larry and i have the exact same phone. If ur lg isnt turning on and wont charge it could be couple things . either the charging port on ur phone needs replaced and or ur charger has gone bad i would take it to a cell phone repair shop close to you.
Mar 25, 2013 | Net10 LG Optimus Logic Cell Phone
I have htc windows 8x phone. My phone wont charge! i plug it in and the red charging battery icon doesn't appears, but it wont turn on no matter how long i charge it. i just got my phone 5 days ag
I think you have damaged your charging pin in the phone by mistake either by dropping the phone or while taking the cord out or inserting. I think the best way to get this fixed will be to go show it to the store that you bought it from/microsoft store. Hope this helps. All the best.
Mar 11, 2013 | HTC Windows Phone 8X
My casio rock wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 31, 2012 | Casio G'zOne Rock Cell Phone
Wont charge. i plugged into so many usb cables and box chargers and light wont turn on nothing charges it
Your charging port is probably bad. It is a common issue. You can take it into an electronics shop and they could fix it by sending it to the manufacturer, but it might cost more than a new phone like the HTC incredible
Mar 01, 2011 | HTC G1
My T-mobile G1 wont come on, it wont charge.
it's your charger get a new one it happen to me
Feb 17, 2010 | HTC G1
My blackberry phone wont power up or charge
It probably wont power up because it wont charge. the USB port may be bad preventing it from charging. I assume you have tried both the wall charger and the computer connection and have not had any luck with either one. Its probably the USB port has stopped working. common problem if the USB cable had been yanked or severely stressed while plugged in to the phone
Feb 16, 2010 | RIM BlackBerry Curve 8310 Smartphone
My T- mobile G1 wont come on and it wont charge when plugged to the socket outlet. it was on before, later i realised it had gone off, am sure my battery is good cos i checked the battery before the phone...
I seem to be having the same problem. I finally figured out that the battery is loose and if I lay it down on it's back, the battery disconnects. Glad I have the replacement insurance as I am taking it back for a new one.
Feb 11, 2010 | HTC G1
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Phone wont charge
You may try to do factory reset of your phone (save your data first!!):
'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
Dec 17, 2008 | HTC G1
HTC G1 Logo
2,518 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
