Question about HP ProCurve 2524 24x10/100 Mbps Networking Switch
Trunk between cisco and hp
How to make trunk between a cisco router and a hp switch. I have entered the follow configuration
FastEthernet0
mac-address 0060.7062.5717
no ip address
speed auto
full-duplex
no ipx route-cache
no keepalive
interface FastEthernet0.1
encapsulation dot1Q 1 native
ip address 147.200.210.10 255.255.255.0
ip helper-address 147.200.3.3
ip helper-address 147.200.5.38
ipx encapsulation NOVELL-ETHER
ipx network 210
no ipx route-cache
no keepalive
interface FastEthernet0.2
encapsulation dot1Q 330
ip address 147.200.180.10 255.255.255.0
ipx network 211
no ipx route-cache
no keepalive
L20
ip default-gateway 147.200.210.10
snmp-server community "public" Operator
snmp-server community "dotnsw" Unrestricted
snmp-server community "Unisys" Operator Unrestricted
snmp-server host 129.223.14.20 "ip" Critical
snmp-server host 172.21.14.134 "Unisys"
snmp-server host 172.21.14.135 "Unisys"
snmp-server host 172.21.14.131 "Unisys"
vlan 1
name "DEFAULT_VLAN"
untagged 1-23
ip address 147.200.210.7 255.255.255.0
tagged 24,25 --à This command make the device unreachable.
exit
vlan 330
name "VLAN330"
tagged 24,25
exit
2 Suggested Answers
ted1430
  • 339 Answers
SOURCE: 3 vlans, data,1; data 2,;voip,5. Ports carry voice
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Posted on Aug 08, 2009
  • 25 Answers
SOURCE: Trying to Configure HP ProCurve 2524 24x10/100
This switch will not function as a DHCP server itself. You will need to have a DHCP server on the VLAN with the access points to give out IP's to the wireless users.
HP has free design and configuration services http://www.procurve.com/customercare/services/design-center/index.htm
Posted on Apr 14, 2010
How to switch on poe function at switch port
Hi
Instructions
telnet to the IP address of the Cisco switch
Enter the telnet access password for the Cisco swict when requested, and then the "Enter" key.
Type "enable" at the command prompt, and then the "Enter" key.
Enter the Privileged Exec password when requested at the command prompt, and then the "Enter" key. Then enter "configuration terminal" at the command prompt, and then the "Enter" key.
Type "interface fastethernet0/1," replacing the "fastethernet0/1" with the name of an interface in which you wish to enable PoE, and then the "Enter" key. Then, while in interface configuration mode, type "power inline auto" and then the "Enter" key. Repeat this step for each interface in which PoE is required.
Type "end" at the command prompt and then the "Enter" key, copy running-config
Below is some commands to run, I don't have any power on the interface but this will show you if this is working...
SW1#sh power inline fastEthernet 0/1
Available:360(w) Used:0(w) Remaining:360(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto off 0.0 n/a n/a 15.4
Run this command to see the interface is up.....
SW1# sh interface fastEthernet 0/1 ' in protocol
FastEthernet0/1 is up, line protocol is up (connected)
SW1#sh cdp interface fastEthernet 0/1
Encapsulation ARPA
Sending CDP packets every 60 seconds
Holdtime is 180 seconds
Thanks
Jul 31, 2014 | Cisco Catalyst Computers & Internet
How to change password
Cisco Linksys E1000 Wireless-N Router Router Default
Cisco Linksys E1000 Wireless-N Router Default IP:
192.168.1.1
Cisco Linksys E1000 Wireless-N Router Default Password:
admin
Cisco Linksys E1000 Wireless-N Router Default Username:
linksys
Nov 30, 2013 | Cisco Linksys Wirelessn Router Black...
Breaking password on cisco 857w
When the router first starts booting you need keep hitting the break sequence which should be crtl+F6 and that should bring you to ROMMON mode. you should get a prompt rommon 1>, that means you did it right. Now you need to change the configuration registers to 0x2142 by typing "confreg 0x2142". then type reset to restart the router. It should now ignore the saved config. hit crtl+c to cancel the initial setup, type "enable" to get to the enable prompt. Next type "copy startup-config running-config" to copy the startup configuration to the running configuration. Next type "configure terminal" to enter global configuration mode. Now you can type "enable secret <password>" to change the password to what you want. Last you need to change the config registers back to 0x2102 by entering the command config-register 0x2102.
Feb 17, 2012 | Cisco 857 ADSL Wireless Router...
How to change admin username & password on cisco 2911 router
agree that turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin on Cisco 2911
http://www.3anetwork.com/cisco-cisco2911/k9-price_p238.html
Nov 04, 2011 | Cisco 2911 Router
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How to create subinterfaces on a 3845 series cisco router? I am trying to setup a trunk port for VLAN configuration. Thanks
Its like router on stick configuration??enter the interface which you have to configure and in that interface as mentioned below
Hostname(config)#interface FastEthernet0/1
Hostname(config-if)#no ip address
Hostname(config-if)#no shutdown
Hostname(config)#interface FastEthernet0/1.1
Hostname(config-if)#encapsulation dot1Q 1 native
Hostname(config-if)#ip address x.x.y.y < subnet mask >
interface FastEthernet0/1.2
Hostname(config-if)#encapsulation dot1Q 2
Apr 09, 2010 | Cisco 3845 Integrated Services Router...
How to create vlan in nortol 3510 L3 switch
You would need to trunk the VLANS to the router and create sub
interfaces and then, create access lists applied to
the interfaces to control inter vlan communication. I hope this helps,
Router interfaces something like this, may not work on all versions of
IOS:
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description VLAN1_Servers
ip address 192.168.1.1 255.255.255.0
interface FastEthernet0/0.2
description VLAN2_QA
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
description VLAN3_DEV
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.4
description VLAN4_FIN
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
Aug 01, 2009 | Nortel Enet Routing Switch 3510-24T Incl...
Cisco error on switch
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Feb 06, 2008 | Cisco Catalyst 4006 Chassis ( 4006)
HP ProCurve 2524 24x10/100 Mbps Networking Switch Logo
1,608 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
