Error code C0 on a AEG Lavamat 76768
When I start my washing machine, it says tick-tick a couple of times, then stops, and the letters CO (or maybe c0, c-zero) shows up in the display, regardless of what program I choose.
I called AEG-Electrolux service, but they dont hand out the service codes.
Anyone knows what CO, means or knows how to get those service codes?
It is an AEG öko-lavamat 76768 "update"
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
Posted on Sep 25, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Posted on Dec 01, 2008
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
Posted on Mar 21, 2009
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
Aeg lavamat error code c6
Found this on the following forum
C6 is caused by either a) defective mechanical pressure switch, b) defective pressure sensor or c) Defective wiring to either a or b.
You may want to just remove the hoses from the switch & sensor, noting what hose went where & blow down them to see if they are clear. If not, trace blockage & clear, refit hoses & test.
Before doing the above, please isolate the appliance from the mains electric supply.
Jan 13, 2015 | Garden
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Aug 24, 2014 | AEG Washing Machines
AEG Lavamat 11842 Error code E66
Feb 23, 2013 | AEG Washing Machines
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Jun 04, 2010 | Washing Machines
E75 error
Looks like micro controller board problem!
Mar 30, 2010 | AEG Lavamat 88840 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Oct 11, 2008 | AEG L86800 Front Load Washer
Washing Machines Logo
306 people viewed this question
Top Washing Machines Experts
