Watched a dvd at night and turned the tv off went to bed and next morning turned the tv on and no picture just a purple patch taking up 3/4 fo the scxreen flashing on and off, no funtions work at all, wont even let me turn it off.
SOURCE: worked one night, next morning would flash on then automatically turn off
Yep, the inverter transformer on the Power Supply Board burned out. It's one of 5 inverters that powers up the screen.
If one is burned out, it will not have enough juice to power the screen and goes into protection mode like it's doing right now.
You'll have to replace the POWER SUPPLY/BACKLIGHT INVERTER BOARD. The cheapest place runs for about $90.
I'm not sure which one you have, there are 2 different boards for that TV. The board number should be in white on your board.
Here's for the BA8AF0F01031
http://www.shopjimmy.com/power-supply-backlight-inverter-ba8af0f01031-from-emerson-lc320em9-5.htm
And here's for the BA8AF0F01032
http://www.shopjimmy.com/power-supply-backlight-inverter-ba8af0f01032-from-emerson-lc320em93-8.htm
It's definitely cheaper than buyig a new TV. That what I did to fix mine. :)
If you throw your old board in the trash, I would like to keep it for research if possible. Here's my e-mail: [email protected]
SOURCE: vizio hdtv 32 inch wont come on.
More then likey you have a bad mainboard. Especially for the 32inch and below its usally the mainboard rather then the powerboard.
The tv parts are modular you can usally buy parts on ebay. I dont recomend soldering or anything like that, just a simple board swap will do.
SOURCE: Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Testimonial: "A quick one to respond with a good answer to the problem."
SOURCE: TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
