Changed modem bigpond 2071a to a 2701hgvw thought could just plug in and off i go.but wont work i dont know username or password that it keeps asking for,i thought i did but no that dont work niether
Username is your Bigpond email username as will be the password. contact Bigpond to reset if you can't remember it
Posted on Dec 12, 2008
How to change my password
In your internet browser navigate to 192.168.0.1, username/pass is admin/admin or admin/password - Wireless settings - Change the SSID text and enter a new password in the WPA encryption
Sep 25, 2014 | NetComm Telstra Bigpond 3g9wb 3g Wireless...
Unlock code
http://support.netcommwireless.com/product/3g/3g9wb
This guide will take you through the process of changing the password required to login to the
administration page of your modem / router / VOIP ATA.
1. Open your web browser and go to the address http://10.0.0.138, using admin as the
username and password.
2. Hover your mouse over the "Advanced Settings" menu at the top of the page, and
then move it to "Access Control".
3. Click on "Passwords".
4. Enter the CURRENT password into the "Old Password" section.
5. Enter the password you would like to use into the "New Password:" and "Confirm
Password:" sections
6. Click "Apply/Save".
You will then be prompted to re-login to the administration page. Remember to use the
new password (and username if you changed it) you have just entered.
Oct 24, 2013 | NetComm Telstra Bigpond 3g9wb 3g Wireless...
How can I change my email address bullentas@eftel.net.au to bullentas@bigpond.com I need to change it to give to Velocity
Your question is confusing, do you mean you need a new email address? i.e. bullentas@bigpond.com? Or something else? You cannot change eftel.net.au with bigpond.com, they are different, but you probably you can get one bigpond.com email address with that username "bullentas". You cannot have "bullentas@bigpond.com" unless you sign up with bigpond.com. Create a new account with bigpond.com and assign a username as "bullentas" and "bullentas@bigpond.com" as email address, but if somebody has already got that username or email address, you wont be able to get them.
If you need further help, let me know with ore details.
Good Luck.
Thanks for using FixYa.
Jul 14, 2011 | Computers & Internet
I want to change the username and password for afaq shamel modem. do i have to restart the modem after changing username and password. moreover, do i have to keep the modem connected with my laptop while...
You should not have to restart your modem after changing the password. Once you change that password you might be promt to enter your new password in to establish an internet connection following the password change. The preferred method to to access your modem is through your computer with the modems IP address.By default most of the afaq shamels passwords are as follows:
Default IP: 192.168.1.1
Username: Afaq_shamel
Password: stccpe_2007
Type in that IP address in any internet browser (Fire Fox, IE, etc) You should be prompt to enter in a user name and password. If the one mentioned above does not work try:
Username: admin
Password: password
I hope that this helps you along the way. let me know if there is anything else I can do to assist you.
Thank you
Jul 05, 2011 | Computers & Internet
I have an optus netgear router model DG834G v5 and trying to set it to work with Telstra Bigpond, but don't know how to.
To bypass the Optus login page type in the address bar 10.1.1.1/CA_HiddenPage.htm
It will ask to disable the Optus login, accept, then close the page, open a new page and type in the address bar 10.1.1.1
And you will be at the router login
Username: admin password: password
Best of luck
Anthony
Oct 01, 2010 | NetGear DG834G Router
I dont know the password for bigpond 5309 and i need it for work or i will get fired
Contact Bigpond to get them to reset/change your password. You need to verify your Bigpond account/username etc with them before they will change your password.
Sep 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Password and username setup
hi merrynlord to connect a bullion to bogpond you must enter the modem set up you do this by opening an internet browser IE or Firefox for instance then type in the address of the modem that should http://192.168.1.254.
Once this is done you will have to enter a user name and password if you changed this when you setting up for supernerd then you will have to use the one you created, if not then the default is
user = admin password = password.
on enter these you should then get a page with a menu on the left, here click on quick start, click
PPoA then enter 8 for VPI and 35 for VCI....altho these settings should already be in there...so baically check them, leave NAT enabled, leave the IP subnetmask and DSN all blank, then where it says username type in your new Username from bigpond and the new password. click apply then click save, and your modem should then connect to bigpond and get all the settings it requires.
If this doesn't connect you let me know.
Oct 08, 2008 | Computers & Internet
I have just relocated property & Iam with Bigpond & have always been with bigpond & when I try to connect to the internet I get an I-primus pop up saying modem misconfigured - bad username or...
If you are using a usb dsl type modem and not a modem/router for connection, go into internet explorer>tools>internet options>connections tab, then look to see that Bigpond is selected as the default dial up.
If you are using a modem/ router which in effect is on all the time, go into the same menu in IE but tick the liitle button saying never dial a connection.
Sep 15, 2008 | Computers & Internet
Forgotten password on login page
Try looking on the modem itself, sometimes they have their default username and password written on them. Try combinations of "user" or "admin". eg username: "admin" password "admin"
if these don't work and you don't know why you can't log into your modem, try resetting your modem using the reset button on it (or holding the power button for 10-20sec) and then try the above suggestion again.
If you still can't login, write back with your modem make and model number.
Jan 09, 2008 | Computers & Internet
Siemens Speedstream 4200 Driver
Visit this link http://www.modemsupport.com.au/. On the left side under the heading Speedstream 4200 download and isntall both the drivers and firmware.
Once you've installed the firmware open iexplorer and goto http://192.168.254.254 . Type in an admin password and save settings. Type in your username and password ( provided by your isp ) press save again and then press connect. you should be in business.
Nov 09, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Computers & Internet Logo
285 people viewed this question
David Payne
David Payne
