HP Photosmart C4485
I have this printer hooked up to my Vista Laptop but am unable to find a driver for the Win2K PCs on my LAN. HP don't supply a driver; surely there's a workround to this problem? Any comments would be much appreciated.
  • HPdrivers Nov 13, 2008
    Same here... I have 3 computers on 2k,2 on xp and 1 on Vista, just the ones on 2K it will not support!
    Any help appreciated.
  • magiawizard Nov 21, 2008
    laptop with winxp work but my old pc with win2k do not install driver
    per my new printer ...... Thanks in advance to problem solver!!!!
I solved following this path.
Locate on installation CD the file inf HPC4400A.INF (or similar I not remember exactly).
Open the dropdown menu (right click on mouse) and select install.
This let me have a working printer in installed printer list.
See my web page in www.webalice.it/magiainformatica.
Gianni.
Posted on Nov 26, 2008
HP Printer Continually Drops Off Vista OS
Click on Start -> All Programs -> HP -> HP Update and run this utility. Last month, HP released an update that directly addresses this issue with the PhotoSmart series printers and computers using Vista. You should install any updates listed here, including the connectivity update.
Jul 26, 2009 | HP Photosmart C3180 All-In-One InkJet...
My printer will not print. It says can not start printer check configuration. My laptop is a vista. printer is hp3210 photosmart
Check the connections. Does the Vista recognize it? If it does, reinstall the driver. Its a maybe that the driver on the installation disc donĀ“t work as well, get the driver from the HP site specifically for Vista.
Jul 21, 2009 | HP Photosmart 3210 Printer
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
Windows Vista and HP C3180 Photosmart all in one
this link might help you get the drivers and any software you might need to get it running on your laptop.
just scroll down the page and look for what you might need.
how to set up HP C3180 Photosmart all in one printer on windows vista...
Oct 31, 2017 | HP Photosmart C3180 All-In-One InkJet...
The software disc supplied with my printer does not support Windows Vista which is installed on my laptop. printer is:- HP Photosmart 3210 All-in-One. S No MY 5BB218X(Q5841A)
Is the Vista is 64 Bit? since it require Digitally Signed drivers for install any device.
And your Photosmart 3210 All-in-one.
Try This link and let me know if the problem still persists.
HP 3213 All-in-One
Nov 01, 2008 | HP Office Equipment & Supplies
My HP Photosmart 8450 no longer prints lines, boxes, etc., since I upgraded to VISTA and MS Office/Word 2008. HP says to buy a VISTA-compatible printer...they do not have an updated driver. Any solutions?
You can use the drivers supplied by Windows Vista
Verify that the printer is turned on.
Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
After plugging in the device, select Don’t show this message again for this device.
Click Continue on User Access Control (UAC) Window.
Go to the Start ( ) icon, click Control Panel , click Hardware and Sounds , and then click Printers .
Click Add a printer .
Click Add a local printer .
Select the Use an existing port check box.
In the Use an existing port drop-down list, select USB001 and then click Next .
Under Manufacturer on the Install the printer driver dialog box, select HP .
Under Printers , select HP Photosmart 8400 series and then click Next .
In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
When the message You're successful and HP Photosmart 8400 series appears, you can print a test page to ensure that the printer is working correctly and then click Finish .
Apr 03, 2008 | Office Equipment & Supplies
242 people viewed this question
jasbo
jasbo
