How do i connect plantronics bluetooth with sony laptop
  • 488 Answers
Switch on the bluetooth on the laptop and make sure you have set it in "discoverable" mode (ie;other devices can coonect to it) switch on the plantronics..use the scan for blutooth devices in range option in the laptop..once its shows plantronics follow the onscreen messages..if it asks for some kind of passkey use 0000..hope it helps!
Posted on Nov 03, 2008
Cant connect to my laptop
Assuming your laptop is Bluetooth compatible, make sure all other Bluetooth devices are out of the area so there is no interference. As each computer may search for the headset differently there is no generic guide as to how to pair up the two devices together. Carefully follow the instructions of the computer for pairing or call Plantronics at 800-544-4660 x5538.
Good Luck from Headsets Direct!
Jul 20, 2011 | Plantronics Explorer 240 Bluetooth Headset
Connect to laptop
If your laptop has a bluetooth application installed in it, it should pair up. However if your computer is not compatible then you would need to get a bluetooth with a dongle; the dongle becomes the application. The Explorer 240 has been discontinued and does not have a dongle. You might try looking at this one.
Plantronics Voyager Pro B230 UC Headset
Good luck from Headsets Direct!
May 21, 2011 | Plantronics Explorer 240 Bluetooth Headset
CAN I CONNECT A THIS TO A LAPTOP? IF I CAN HOW?
You can use the Plantronics Explorer 240 on your computer if your computer has Bluetooth built in. Just turn on the Bluetooth feature in the computer and pair up the headset. You can get a USB Bluetooth adapter if your pc doesn't have Bluetooth built in, then just pair the headset to the adapter. Here is a link for the 230 / 240 user guide, it will have the pairing instructions for the Explorer 240.
Plantronics Explorer User's Guide
Mar 17, 2011 | Plantronics Explorer 240 Bluetooth Headset
My bluetooth Plantronics 220 won't turn on
my plantronics will not connect to my htc diamond without being on the charger.when i take the bluetooth off the charger it will not connect
Nov 19, 2009 | Plantronics Explorer 220 Bluetooth Headset...
How do i connect plantronics 330 to my new phone? i have the bluetooth connection on on my phone but it doesn't seem to read it. Its a Sony Ericson W980
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Jul 14, 2009 | Plantronics Explorer 330 Headset
how do i set it to serch mode so it will find my phone or vice versa
Jun 19, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    Computers & Internet Logo
    202 people viewed this question
    David Payne
    David Payne
