Question about Samsung CLP-300N Laser Printer
Samsung printer CLP300
Paper jams every time it attempts to print. No blockage juts will not fed paper through.
  • 4 more comments
  • benni789 Nov 03, 2008
    Printer jams every time, pulling paper only 1/3 page in and stops with red lamp on, after opening the cover and close paper comes out flat but printed in mirror and not complete. Printer gets very hot, I think more than as it was new. When it is very hot then the printer prints sometime print normal in good quality.
  • pajamapartie Nov 22, 2008
    I do have exactly same problem. Glad to hear it doesn't sound my fault. I had this for 4days and apart from the problem, I also have colour issue. It print different tint of color but it's all same illustration placed on different files.
    hi benni789
    I have the exactly same problem you stated. You have described it so clearly.
    I'll be going to Samsung service centre in Rozelle (Sydney) tomorrow. and will let you know how it went
  • Kimogrande Jan 09, 2009
    Paper will not feed and there is no jam - only a few months old - frustrated
  • russjones Jan 19, 2009
    Exactly the same problem - paper traps 1/3 way in every time
    I can eventually get it to print but bizarrely only by squeezing the back drop down panel against the  printer and then it works - internittently.
  • Anonymous Feb 15, 2009
    My printer jams every time.  I followed the answer given by one of your email and pressed the tray and back at same time and it did print.  I don't  want todo this every time though so any other help would be great.
Clean the rubber feeder belt with alcohol. Worked for me, Yesss!!!
Posted on Jan 24, 2009
I had this problem during warranty. The Samsung Service came to me and replaced a rubber transport belt at the first shaft. He said that it was probably a bad series of the rubber. The print is stopped because the paper is transported too late, so the print is shifted to the top of the paper. I think cleaning of this rubber will help. Take out the paper, you will find the rubber transport roller (it not perfectly round) in the middle from below the printer.
Best Regards
benni
Posted on Jan 25, 2009
MY SAMSUNG PRINTER CLP300 IS NOT LOADING THE PAPER AT THE TIME TO PRINT HOW CAN I RESOLVE THE PROBLEM?
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 13, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
My Samsung CLP300 has a paper feed problem. When
Lift up the front of your machine about 4 inches with a book.
The paper will now feed easier.
Richard
Oct 27, 2009 | Samsung CLP 300 Laser Printer
CLP300 not picking up thicker paper
this printer only supports up to 120gsm paper,any thing thicker will get jamming errors
Jun 12, 2009 | Samsung CLP 300 Laser Printer
Paper will not feed
Check if a piece of paper is still left from the paper jam. Sometimes pieces of paper get stuck behind the feeder roller if the paper is torn while removing the jammed paper
May 23, 2009 | Samsung CLP 300 Laser Printer
Doesn't print
You may need to empty the excess toner bottle, it's in the front, to the left side.
Oct 06, 2008 | Samsung CLP 300 Laser Printer
Clp300 paper jamming
Section one is usually the bypass ( the front tray that you have to open the door)
it is trying to print from there
otherwise clean the tires in the tray area with alcohol, they probably contain dust and the paper is slipping.
Aug 07, 2008 | Samsung CLP 300 Laser Printer
How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
Get rid of it. Your problems will only get worse. Mine is going to the landfill.
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP-300N Laser Printer Logo
281 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
