Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Red lines when my tv has a dark or black image it has red bowed lines in it or when you change the channel it has the same problem. thanks for any help
The top of my screen is pink and the color kind of bows down. The images are kind of distorted. Thanks for any help.
Posted on Apr 16, 2008
TV Problem: No Video but Audio works
Here are some basic treatment for a dark display.
  1. On LCD TV, Some time missing or lose LCD strip from PCB connector. Solution- Clean strip and connector.
  2. Some time missing LAMP, burning lamp is a major cause for dark display in LCD TV. If lamp problem with any display, Display show in sun lights. Solution- Check Lamp connection/connector. Clean connector or change Lamp.
  3. In CRT TV, Fly back is faulted. There are no high voltages. Solution- Change or check fly back, Check out put transistor.
  4. Some OLED Tv Use OLED lights for display shining and brightness. IF LED's or lamps are faulted there is no display in sun shine.
  5. Before starting Troubleshoot display problem you need to conform and trace faulted stage of TV.
  6. Don't Apply any miss use trick at home. Contact the professional repairing lab.
  7. If you are full fault to understand your TV problem. Tip more condition of your problem.
Jul 02, 2015 | Element Televison & Video
I,ve got a red spot in the screen i replaced the bulp but stil have the problem
it is most likely a burned polarizing filter. There is a polarizing filter on the blue light channel and another on the red channel. When black, or other dark colours are displayed, the red polarizing filter is supposed to block ALL of the red light being projecter. If the filter is burned, some light slips through and creates a red tinge on the projected image. If the red tinge only appears on dark images, but is absent when the images is completely white, a damaged filter is likely the problem.
Seems its hard to buy them. Best bet is probably buying a broken projector from ebay and stealing the filters out of it.
Oct 04, 2010 | Toshiba TLP 670 Multimedia Projector
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
BAD PICTURE, DISTORED, MOSTLY ON THE EDGES, BUT THE BLACK LINE ON TOP IN HIGH DEF CHANNELS IS NOT STRIGHT ACROSS, IT BOUGHS DOWN LIKE A "U" SHAPE
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 15, 2009 | Sony KP-51WS520 51" Rear Projection...
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Green flashing screen
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 26, 2007 | Toshiba 57H82 57" Rear Projection...
Sony kp-51ws510 51' projection tv
There are resistors that need changing and maybe small fuses.
Nov 28, 2007 | Sony KP-51WS510 51" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
