Question about Philips 52PFL7432D Television
LCD TV wont turn on and red LED flashing error code
If I am lucky I can get my 52PFL9432D/79 to turn on and then it seems OK. If I turn it off and then back on again within 10-15 minutes it tries to turn on but after some relay clicking it fails and I get the red standby LED flashing 5 times slowly and three times quickly. If I then unplug it for an extended period, it will usually start after I plug it back in.
It also seems to take forever between pressing the ON button to showing an image. Sometimes it will give sound at start up but no picture. Change channel, and the picture appears.
All help appreciated.
  • Anonymous Nov 17, 2008
    same with my samsung 32 inch lcd tv.
  • 223 Answers
SOURCE: Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Posted on Oct 03, 2008
  • 44 Answers
SOURCE: Philips 42PF7220A/37B shuts after 10-15 min. LED Blinks 5 times
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 188 Answers
SOURCE: no picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Posted on Jul 21, 2009
  • 5 Answers
SOURCE: Philips 20PF4121 LCD tv no picture but flashing error codes
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Posted on Sep 23, 2009
SOURCE: TV wont come on
I just fixed my 50pf7220a phillips last nite....i took the back off and found two bulged capacitors on the power supply board...i tried un soldering them in order to repleace them but could not get them hot enough to melt the solder.....so i called this number (812) 867-7583 to get a new power supply......tell them the model number of the tv and they have the power supplies in stock mine was 129.00...the power supply is the large circuit board near the center of the tv.....its easly to replace....lay the tv screen down on the floor remove the large back ....about 70 screws....look for the slighty bulged capacitors...on the power supply board.....label all of the connectors to the power supply board and make a map of where they go .... remove the 8 screws that hold the power supply board in place.....get the new board and rehook....making sure that all connectors are tight.... please use two people to move this tv its top heavy....good luck if you have questions please post here and i will try to answer.....I am not a tv repairman but just a concerned consumer.....i understand that capacitors will go out once they reach 2000 hours.....
Posted on Feb 21, 2010
My Hisense 50K23DG T.V. wont turn on?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Aug 22, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
Tv picture does not come on , sometimes works after being on for at least an hour. when turned on screen appears blue with vertical lines or white screen.
i started having this problem today, on the 52pfl9432d/79 i am pissed off bigtime, lucky its still under warranty, and this is not a once off problem...so i shouold be able to get this resolved within 24 hours just got to find my reciept.....lol
i have sound no picture or menu to change settings, very disappointing..
Dec 22, 2009 | Televison & Video
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
Flashing light
The LED used in most tv are dual color led,some have two lead, some have three. try to find the same size and replace it.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips Cineos LCD TV doesn't turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 18, 2017 | Televison & Video
Remote control (UBRC-120) will not work the unit.
I had the same problem. resolved it by the following......
1. Press and hold the TV button until the red LED turns on and stays on.
2. enter 00000, the red LED will flash and turn off
3. test remote
This procedure should put the remote settings in default for TV.
if all goes well remote should operate the TV
Oct 05, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 52PFL7432D Television Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
