Question about SanDisk Sansa e260 MP3 Player
SANSA IT WILL NOT CHARGE IT LICKE ITS WORTHLESS
  • 758 Answers
It sounds like the battery on your device could be defective...I would recommend you to change the battery..Once you do that the device should be up and running
I hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Nov 03, 2008
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    This isn't a problem (I hope) but my Sansa clip didn't hold a charge for very long. Can I use my cell phone charger to charge it? It fits the connection fine.
    Yes, assuming you're referring to the connection at the end of the Sansa cord and not on the Sansa itself. The Sansa can be charged by any USB device or port that puts out sufficient current.
    Dec 06, 2010 | SanDisk Sansa Clip MP3 Player
    HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
    The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
    Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
    Error the filename directory name or volume label syntax is incorrect when i connect my mp3 player
    u shuld probably purge it, right lick, and format, but save that as a last resort, try right clicking, and renaming it
    Sep 29, 2009 | SanDisk Sansa c200 MP3 Player
    Sansae250
    connect to your pc using usb connection. sansa should be recognized as storage media drive. navigate to the drive. Drag and drop files to music/video folder. Enable show hidden files and folders in your windows folder settings. Tools>Folder Options>View. Some of the folders are hidden. You can delete the preloaded music also.Some of them are in the radio folder.
    ThePlague...
    Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
    Sansa M230
    I don't have a solution I am trying to get mine to work. Did you ever get yours to work? This must be the most worthless piece of junk MP3 player ever.
    Nov 11, 2007 | SanDisk Sansa m230 MP3 Player
    Sansa won't charge or load.
    Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
    Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
    Weird file in my Sansa e250r.
    go to www.download.com and search for a program called Unlocker 1.8.5 it's free... after installation, right click the file to unlock the file and it should be fixed to delete... I was on here cuase my unit froze...
    Jul 31, 2007 | SanDisk Sansa e250 MP3 Player
    SanDisk Sansa e260 MP3 Player Logo
    16 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
