Question about Sony KV-32V26 32" TV
ABL protection active & color's spots
Initially the TV not had audio and video 1)first I change a resistance of 1 ohm in power supply. 2)Now I had audio but no vert. sweeping & shutdown at few seconds for ABL protection. 3)Then I changed the IC vert. out. but ABL protection is still present. 4)If I disconnect ABL protection (pin 11)the picture stay like a pattern with vertical but not good defined colors. 5)reconecting ABL give a failure code with 2 lights, then shutdown and give 4 lights. All ICs and transistor under this codes it's ok. The TV it's a SONY KV29SL42/5 I need helppppppp!!!...
  • ARTURO VEGA Sep 29, 2006
    I see that the vert. IC was wrong, I buy 3 TDA8172 and the store gave me 1 TDA8127, by coincidence this last was that I changed and then since the point 4) to ahead, in this moment I put the correct vert. IC and I'm like the point 2), the pattern with vertical but not good defined colors has gone.
    thanks in advance.
    President:
  • 3,130 Answers
Replace the capacitor and the resistor as well as the diode that feeds the b+ to the vertical IC.
Posted on Sep 28, 2006
Am/fm tuner no power
Try changing the cable/transformer for a new one. you should be able to find a new cable online easily enough, or maybe a friend has one you could borrow.
Try a different power outlet.
Make sure your multi-plug (if you're using one) is functional.
Try plunging something that you know works, in the outlet, to see if you have power at that plug.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
It could be a fuse in the Tuner, replace the fuse for a new one.
Get your Multi-meter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 10, 2014 | Sony Audio Players & Recorders
Compresor on and off
Its normal for it to start and stop.
Check the mountings are tight
Some of this might help...
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 10, 2014 | Refrigerators
Motor will not start
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 10, 2014 | Cuisinart DFP14 Food Processor
How to repair
A wire might have come loose inside the Vacuum head.
Remove/Dismantle the Vacuum head and locate the wires.
Check the wires at the terminals and at pinch points
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 08, 2014 | Hoover S3670 WindTunnel Bagged Canister...
U5445-900
This is a good start, try this link...
Product Manual Search
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 02, 2014 | Hoover U6630-900 WindTunnel Bagless...
My hoover vacuum does not power up
Here s a link to the manual
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 15, 2014 | Hoover S3330 / S3332 Straight Suction...
How to replace power cable on hoover jc3157t
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 04, 2014 | Hoover Vacuums
Wiring
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jun 11, 2013 | Yamaha RX-V757 Receiver
Samsung 32" LCD tv, No picture with audio
i will first resolder all ic`s and connections,especiall on the crt board,clean around the flyback at the abl circuits,check for open or changed valued resisters in abl circuit and the video b+ on the crt board (usually 165-200 volts) check also the screen voltage (G2) volts,should be around 250 - 400 volts.
Sep 18, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Avr 3806 power shuts off when volume turned up
Hello david 420
It looks like your receiver's high-speed protection circuit is being activated. It is definitively not a fuse. When a fuse pops, you have to physically replace it. When the protection circuit is activated, the speaker output is cut off and the power supply indicator flashes. There are a few reasons why this happens:
1.- Your speaker wire connections are loose. Whether they are banana plugs or bare wire ends, make sure the speaker terminals on the back of your receiver are tight using clockwise turning.
2.- Verify that your speakers have an impedance between 6 and 16 ohms. Your receiver was designed to work with that impedance range. Any impedance lower than 6 ohms will activate the protection circuitry.
3.- The receiver is used at high volume levels over a long period, which results in an
extreme temperature rise. Improving the ventilation conditions around the unit might help alleviate the problem.
If after complying with these suggestions, problem is still present, you might need to have the unit checked by a professional for possible circuit failure.
Hope this helps. Let me know.
cancerags
Dec 31, 2007 | Denon AVR-3806 Receiver
Televison & Video Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
