Question about Garden
Fuel air lock in Grass Scorpion trimmer
Primer bubble does not fill with fuel. Air lock somewhere in the line. How do I fix it?
  • SoreArmRay Nov 24, 2008
    I have the same problem, and suspect the fuel lines are mixed up.
    So far I got this from the web
    RYOBI Grass Scorpion
    Fuel lines
    1 - outlet from feul tank -> primer inlet(short writen IN)
    2 - free end of primer(long) -> spigot (brass) on top of carby
    3 - spigot at the buttom of carby -> fuel tank
    fuel line from tank goes to primer inlet which is shorte one (on top of it writen "in") and come out from other end of primer then connec to spigot at butom of carby ( L shape one) ?
    Farshad, you are wrong!- The line from the tank goes into the longer inlet, and the line into the carbie goes into the shorter inlet.
    Plug
    RST310SS,RCT2800A to 1/1994
    Model Standard Plug Gap (mm)
    Grass Scorpion T20M-U 0.6
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 28, 2008
Why my weedeater idle to high and why air bubble in the primer bulb?
Its not un common to have air in the primer bulb, Check for a possible air leak in the system. This will make the saw idle higher than normal if its sucking air from elsewhere.
May 19, 2016 | Garden
Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Oct 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
I have a poulanpro gas trimmer ppb335. when i pump the bulb, I can see air bubbles coming from the carb to the pump bulb but not from the tank to the carb. where is it coming from?
There could be a bad check valve in the carb or a gasket leaking or even a pin hole in the fuel line. Since its the primer bulbs job to remove air from the carb and replace it with fuel; as long as the unit runs fine I wouldn't worry about it. A leaking gasket can be fixed with a rebuild kit. Bad check valve will require replacing the carb.
Aug 22, 2014 | Poulan Pro PPB335 33cc 17-Inch Gas Line...
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
I have a TB70SS trimmer. I used my trimmer on half my yard with no problem, turned it off to cut the grass with the lawnmower, then tried to turn on my weedeater again, and noticed the primer bulb would...
First, the primer/purge bulb does NOT have to fill completely to function. It's purpose is to remove old fue and AIR from the fuel system (carb) and move it back into the fuel tank. You normally will have an air pocket in the bulb. An air leak in the fuel system or loose carburetor screws or fuel lines in the wrong location can cause your problem. Check the fuel line and fuel filter for a good connection in the fuel tank. Remove the fuel pump cover on the carb and make sure the very small, round, wire mesh filter is not clogged with debris. When old fuel lines deteriorate, they crumble and if the filter is broken off, the fuel line to the carb will ingest bits and pieces of old fuel line. Check all these things and post back.Sometimes, if the bulb is on the carb, a check valve in the carb can stick. When you check the condition of the mesh filter inside the carb (opposite the side with the vent hole), then liberally spray with WD 40. Strong solvents and cleaners can SWELL up the tiny check valves in the carb, causing problems. So you see, it is hard to pinpoint exactly what happened without some removal of parts and diagnosis.
Aug 06, 2011 | Troy Bilt Tb70ss Gas Trimmer
Primer bubble is cracked.minimal fuel is getting to carburator. when it starts it will run a few seconds then cut off.Won't run except in full choke. Please Help
The primer bulb needs to be replaced. It is introducing air to the system and not allow fuel to flow. Replace it and check the fuel lines while you are at it.
HTH
Good Day
Oct 29, 2009 | Craftsman 25cc Gas Line Trimmer
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Manual for Ryobi Grass Scorpion Line Trimmer
my ryobi scorpion only has twofuel lines but two on primer can you help
Mar 13, 2009 | Ryobi Garden
Weed trimmer
no, the overflow line does not need to be submerged. first make sure that the hose connections are tight and the "O" ring or gasket inside the gas cap is not damaged or missing. when replacing both lines at once, its easy to get them mixed up, so make sure they're not. remove the carbuerator and inspect the gasket; it should be soft and flexible, if its hard or brittle it needs replaced. it doesn't take much to clog it, so spray carb cleaner, available at local auto parts store, inside the fuel rails and blow out with compressed air. there might also be a pin hole or bad seal in the primer bulb and need to be replaced.
Oct 16, 2008 | Garden
Garden Logo
702 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
