Question about Kenmore Dryers
How to open kenmore elite dryer control panel
I have a Kenmore Elite gas dryer (Model: 74996) that I purchased in 2003 that has stopped working all of a sudden without any warnings. It was working great while it did. Now the drum spins without heating the clothes as long as the Start button is kept pushed. The moment the Start switch is let go off, the dryer stops immediately.
I tried opening the control panel by taking off screws on the outer backsides of the control but I still don't have any idea of how to take the control panel apart for further investigation with a multimeter. I opened a small square plate from the rear side of the control panel and took out the service technical sheet and tried out the instructions on troubleshooting the dryer by getting the dryer into the test mode. But the dryer wouldn't even enter test mode.
I read on the web that the EvenHeat computer board on Kenmore Elite had lots of issues, and I am wondering if my symptoms point to the same issue. Would someone please help me with instructions on how to take the control panel apart, with possibly some diagrams or photos of a similar model?
Any help is greatly appreciated.
Thanks in advance,
-Vish
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
IFIXALL
  • 868 Answers
SOURCE: Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Posted on Aug 11, 2008
  • 958 Answers
SOURCE: Kenmore Elite Dryer, Model: 110 60972990... will not restart.
yes, a DIY person can replace a thermal cutoff. just open the rear of the unit and look for parts with big red wires connected to it. it is round, one small and one big. both have two terminal clips.
if you can find the schematics inside the switch panel, then it would help you further. the thermal cutoff consist of two pc. replace both even one of them has continuity.
tnx 4 using fixya,
drcool
Posted on Sep 29, 2008
SOURCE: Kenmore Dryer
I had this same problem a couple of years ago. I replaced the circuit board located in the top part of the dryer and it has been fine since. The part cost $95 over the internet.
Posted on Jan 12, 2009
  • 17 Answers
SOURCE: dryer will not heat
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Posted on Mar 25, 2009
How do I stop fluff cycles on kenmore elite dryer
There are two ways this can happen:
1. You set the timer to a cycle that activates this option
2. (If equipped) Turn the selector knob off on the control panel that you can activate this feature with. Every manufacturer calls it something different.
May 12, 2012 | Kenmore Elite Oasis 7808 Gas Dryer
Tip
Kenmore Elite & Whirlpool Duet Washer and Dryer Control Panel Locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
on Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite HE 4 just stopped heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 06, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore gas dyer, model 11170092991. Won't start. Control panels lights work. when "start" button is pressed nothing happens
Hi
If your dryer doesn't work or start please check the bellow link to troubleshoot your problem :-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#itdoesntworkatall_electric
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Hello, our Kenmore Elite Dryer panel isn't working . I'ts getting power but the panel is not responding.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
Elite 45986 Front Load Washer: HI My lchild lock was activated on my kenmore elit...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Elite 45986 Front Load Washer
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
Mar 28, 2009 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore elite double oven control panel
I just purchased the kenmore elite double oven with the touch pad control centre. Has anyone had any problems with the control panel on these ovens?
Dec 13, 2008 | Kitchen Ranges
Dryers Logo
325 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
