Question about HP Computers & Internet
Computer starts up fans and all that work but no image on screen
  • kepa12 Nov 03, 2008
    I get a System Recovery Options box that comes up but dont no why or what to do
    Master:
    Sergeant:
  • 461 Answers
This may be because of your registry.. can below link that might be helpful for your problem...
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
hope this helps...
Posted on Nov 03, 2008
Monitor does not show images all the time What should I do?
Hello Stanley,
There is a few things that it could be, changing the cable is a good initial troubleshooting. When you get the computer up and running you can try and make sure that all the drivers for your video card are updated to the latest version. You can find them on your computers manufacturer support page or if it is an aftermarket video card it will be on their support page. Now as for the ticking sound, it could be that a fan in the case or on the video card has failed or is starting to fail. They are fairly cheap to replace only about $5 - $15. It could be the reason that your screen is black as the video card may be overheating due to fan failure. If you are comfortable opening the case to check on the fan while you have it unplugged from power. You can check each fan in the case to see if it turns freely. If none of this works and you still have the problem, then it may either be a power supply problem, or the video card could be giving up. Please keep in mind this is just a general diagnosis since you have not provided any error messages or system specs.
Mar 07, 2015 | Computers & Internet
My compaq nc6220 laptop wont boot up . it starts up gets by first screen then about 15 seconds after that it resets. also after first screen fan stops. ive tried last known config that works, safe mode etc...
Most likely your operating system is corrupted. There a couple things you can try but you will need a second computer to create a bootable disc, or if your computer has a build in recovery partition you might already have the tools required.
  • Do you have access to a second computer?
  • Do you know how to enter BIOS?
  • Do you know how to burn an image to disc?
Comment back with what you know how to do and don't and I will walk you through it.
Aug 06, 2011 | Computers & Internet
My lap top was working fine yesterday , but when i went to turn it on today the startup said to use "run in safe mode " or others options similar to that , i chose one , & it still didn't...
Hi, sorry to hear you are having problems. 1. Start up your desktop as normal but as soon as it starts keep pressing the 'F8' key. 2. You will have a black background with white writing on and lots of options. 3. Use the up and down arrow keys and select last known good configuration, then press the enter key to select it. philswift_4.jpg
Your computer should start up. If you have a blank screen, do you hear the fans whirring and see lights on the front? If so then your computer works but is not sending s signal out to the monitor. Check all cables to make sure they are securely connected. If you still have no image. Swap your monitor for a friends one that you know works. This will test if it is your monitor that has failed. If you see an image on your friends you will need a new monitor or new monitor cable. If you do not see an image on your friends monitor and your PC has lights and fan whirring then you need to get a new graphics card. If you have no lights and no fan whirring it is outside the scope of this and we need some more information as it could be 1. Failed power supply 2. Failed memory 3. Blown motherboard 4. Failed processor
Please report back with answers to 1. Do you hear fans whirring? 2. Do you see a power light/led light up? (in example pic it is green) 3. Do you see the HDD (Hard Disk Drive) LED/light flash at all? philswift_5.jpg
Many thanks for your information
Phil
Dec 04, 2010 | Computers & Internet
No signal to monitor
Hi, Have u tried removing the RAM and CMOS battery and then again put it.
Jan 25, 2010 | eMachines T6534 PC Desktop
My monitor suddenly lost signal and hasn't returned
do you mean the processor fan that is located near on the left top corner on the motherboard? if that stopped working then turn of your pc immediately. probably the cpu overheated. if that fan does not work replace it immediately as it will burn the cpu.
Nothing happens on screen when booting computer
Hope this helps
Oct 06, 2009 | Abit AN-M2HD Motherboard
Hp pavilion zd8000, has a problem with the graphic card; the fan went dead that on top of graphic card, so when I turn system on, after a few Minutes the screen start to lost image. Do I need to replace...
if the computer works fine for the first few minutes without the fan spinning, you probably only need to replace the fan. when the image is fading, do you get lots of flashy colors? that's mostly a sign of graphics overheating...
Jun 24, 2009 | HP Pavilion zd8000 Notebook
Print screen key on computer.
On a windows computer by hitting print screen you are only copying an image of your computer screen to your clipboard you then have to paste it into an imaging program and save it. For example ... hit the print screen button on your keyboard -> go to start -> programs -> accessories -> paint -> then click the edit menu and click paste you should then see the screen shot of you computer in the paint window you then can go to file -> save and save the image somewhere on your computer.
Mar 22, 2009 | E-Machines eMachines Desktop PC
Screen goes blank on Log on
Use PC wizard (search and download) this will detect all drivers needed on your computer note name and number for your video card type into search engine IE ati x300 drivers for your operating system xp vista you should be able to download correct drivers
if does not work for you please leave reply what happens
Jul 23, 2008 | HP RADEON X300 SE, (128 MB) PCI Express...
Screen does not maximise automatically
reinstall the driver for your monitor or adjust the resolution in the desktop properties
May 14, 2007 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
