Question about USA Spec MERC99 6-Disc CD Changer
USA SPEC MERC99
I just got the unit and when I plug all the wires in I get power and my car recognizes it. The problem I am having is that after I loaded one of the CD magazines into the unit the player tried to read the disc on tray 6. Now tray 6 is stuck and will not retract back into the disc magazine. I don't know how to get that disc tray back in so that I can eject the disc magazine.
Unplug all the cables, leave it out for several hours then replug it in and eject. This happen to me, I called 1-800 Mercedes and that's what they told me and it worked.
Posted on Sep 05, 2008
What is the power of engine bmw 633 csi coupe 1980
633 CSi was powered by a version of the M30B32 engine (145-147 kW +/-197HP in Euro spec, 128-130 kW +/- 170HP in USA spec)
Oct 30, 2017 | BMW Cars & Trucks
No spark 2002 Jeep 4.7
02 jeep, no model stated but seems to be grand Cherokee.
answering for USA cars only not exports, etc.\
GC is WJ jeeps, real name. WJ.02
I can see you didnt scan it first.
crank for 5 seconds and see if the scan tool tells you why it cut spark 99% of time it will
ours has 8 cop coils, 8 coils over plugs.
if all 8 are dead.
then.
1: CKP or CMP sensors dead.
2: the PCM on this car , can cut spark if P0016
code for cam out of time.
they do that so you dont bend the head valves. over.
since you skipped the most important step, SCAN IT.
i cant work to the end, or solve this.
if you have spark for 3 seconds, and it dies after
that is the ASD dropping out, and is PCM command to do that, and the scans tell you why, there are 1 to 8
reasons why, (codes DTC) stored,
make sure the PCM IOD, fuse is not missing or bad
this is the PCM memory fuse, keep it working.
or data can not store.
Dec 27, 2016 | Jeep Cars & Trucks
Ignition module diagram
2007 2.7L hilux
what country is this car, (1million posts and not 1 said yet)
this is USA forum.
Seventh generation (AN10, AN20; 2005-present) 2.7 L 2TR-FE I4 engine. Gas too.
go to your country Toy dealer
and ask for the factory service manual
read the ignition chapter, and wiring chapters
bingo.
or online books dont have your car, only usa spec cars.
here.
or join a toy forum in your country is a win, big time.
Aug 18, 2014 | 2007 Toyota Hilux 2.7
Cant fond obd plug for Honda logo
its and DLC jack, for scan tools .
in USA, can answer until that is answered
oBD2 is usa, OBD is diff. all over the world.
if by chance the car is USA spec, car its, usually 1 meter from
center of steering wheel. or a yard.
the FSM states. (USA)
The 16-pin OBD-II compliant DLC is an electrical connector with a gray housing located under the dash behind the center console on the driver's side of the vehicle.
Dec 02, 2013 | 2000 Honda Odyssey
What aftermarket stereos will work with usa spec scd-f100
That unit is designed to work on Ford vehicles that have a CD button but no CD changer.
Oct 13, 2012 | Ford F-250 Cars & Trucks
European Wiring harness not compatible with US bought Stereo
This is not as straightforward as you may think.
You can certainly buy a generic adapter harness which will plug into the European DIN harness and then provide you with the bare wire tails to patch into. You may even find one which plugs directly into the rear of your head unit without the need for patching.
But you'll find that your head unit still won't work properly as the US uses a different FM channel range to Europe (US frequencies are odd, e.g.102.7, Euro frequencies are even e.g.102.8). The channel spacing is also different.
The radio itself cannot be converted, but you may be able to buy an external converter. It won't be cheap, and the head unit display will still always show the wrong frequencies. Channel changing may have to be done directly on the adapter and not on the head unit as I don't think that the DEH-P3000 has any way to communicate a request for a channel change to any external device and this also means that radio channel presetting may be impractical/impossible.
Considering that the DEH-P3000 is an obsolete unit and nothing special to begin with you can buy a brand new Euro-spec head unit of equivalent quality for less than the cost of adapting your unit and it will work correctly without any awkward Heath Robinson adaptations.
Sell your Pioneer back to the USA where it belongs or bin it as it's useless over here.
Jan 24, 2010 | Pioneer DEH-P3000 CD Player
USA SPEC PA11-Vol unit will not play iPod using the iPod cable.
where did you plug this behind the radio ? or at the cd changer cable ?, the interface needs to be plug into the radio not the cd changer cable
Dec 20, 2009 | USA Spec (PA11-VOL) for iPod
Does the radio on a 2003 pontiac vibe have an rca plug in the bac
Usa spec Ipod adapters usually interuppt factory wiring harness.... rca plug on Usa spec is usually for aux input (line level input)... USA spec is a good piece though provided its application is correct for your vehicle, look up your car on crutchfield.com to be sure
Apr 08, 2009 | USA Spec Ipod Interface Gm
Merc99 6-disc cd
your problem could be several things you need to have it checked out some times it can just need cleaning.
Dec 07, 2007 | USA Spec MERC99 6-Disc CD Changer
Inoperable CD changer
Hi the alpine/merc/bmw cd changer all seam to suffer with the same problem, they say no disc, or no mag try firmly hitting the mag with the handle of a screw driver. the loadinga arm, tends to get stuck. you could try using some grease on the arms, and levers, white spray gease works best. but dont forget to cover the laser beforehand, you dont want grease on it :) Mark www.carradiospares.co.uk
Mar 27, 2007 | USA Spec MERC99 6-Disc CD Changer
USA Spec MERC99 6-Disc CD Changer Logo
266 people viewed this question
Top USA Spec Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you an USA Spec Car Audio and Video Expert? Answer questions, earn points and help others
