A grumbling voice is produced while taking copies
Dark copies are produced while taking copies and alos with a loud grumbling noise
  • rugegt May 11, 2010
    error code e065 for canon 6035
  • 25 Answers
What is the model number of the machine
Posted on Nov 03, 2008
Loud noise when power steering is on full lock Kia Sedona 2004
There may be 2 possible causes for this problem. THe first may be cv koints failing or excessive turn angle of the wheel which would be binding up the cv joint. This can be checked by a wheel aligner testing the maximum turn allowed at the wheels.. The second is that power steering pumps should never be operated at tight full turn. To umnderstand this consider this. Power steering pumps are only under load when you move the steering wheel ans if you turn a bit the pump moves the wheels and then the pressure is let off until you move the wheel again. You have to move the wheel to shut off a valve in the box that allows the pump to build up pressure. When you hold the wheel hard against the stops at full turn you are making the pump work at maximum pressure and if you continue to do this you can expect premature pump failure. Jusat turn until you hit the stops then ease off a fraction. The noise I expect is the pressure relief valve in the pump is releasing rapidly and it probably sounds like a hammer hitting something metalic. Try the alignment and try not holding the turn hard at hard full turn. Haveing the pump pressure checked might also point to a fault
Feb 07, 2013 | Kia Sedona Cars & Trucks
Fiat Punto belt produces a grumbling noise - HELP!
It's the belt tensioner, don't listen to muppets
Jun 13, 2012 | 2006 Fiat Grande Punto
When the washer goes into the spin cycle it sounds like a loud grumbling noise when it at top speed and getting worse almost with every wash.
It sounds like your bearings are going out, they should be replaced and probably by a professional unless you really feel like taking the job on.
Jun 08, 2011 | LG Washing Machines
Grinding grumbling sound upon start up , continuing at a quieter sound during the cycle, loud and grumbly during shut down
Hi.
f you get a very loud noise coming from the machine, and this noiseislouder when it spins faster, then it is often because of a problemwith the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Maytag Dryers
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Copier prints too dark
Clean the mirrors ,lens ,optical unit.
Jul 10, 2009 | Office Equipment & Supplies
I have singer sewing machine model 7422 for two years now. I bought it from walmart in Michigan U S A.I always had singer sewing machines .but I am not satisfied with this one at all although it is...
It's a loud machine.
If you have kids or you simply don't want anything that's noisy, then you better look for another one. This equipment produces noise than may annoy you.
Get the bobbin case fixed, and find a sewing machine store that takes trade ins.
Aug 17, 2008 | Singer 7462 Mechanical Sewing Machine
I have a 99 grand am that has a loud annoying grumbling noise.. but only in drive.. once it gets to about 20mph
Wr as well.hat happens when you do the same in reverse gear? Is the noise still there? Try different position of the gear leve
Jul 18, 2008 | Pontiac Grand Am Cars & Trucks
Have to talk loud...
You could check and see if anything come between you and the mic on your phone, if you can hear them clearly then you mic(part you talk into) may be clogged by dust, dirt, water or just defective.
Aug 12, 2007 | LG enV VX9900 Cellular Phone
59 people viewed this question
jasbo
jasbo
