Question about Panasonic KX-P1695 Matrix Printer
Panasonic kx-p1695 multi-mode printer (136 col)
I want to set my right margin to 136 col since it is set to 80 col but i don't have the manual. what is the procedure? how it is done?
I am having the panasonic printer,the model no.is kx-p1694 but the problem is the head of this printer is damage.I need new head of this printer .If u find the head of this printer then email me . My email id is vishalbhavna@yahoo.co.in
Posted on Jun 01, 2010
Firmware required
If the the printer will only print 80 column rather than 136, and you know your print job is 136 columns, firstly check the menu settings to ensure the printer is not set to 8inch width. If the printer is set to 8inch width you will not be able to print more than 80 columns.
If you are printing from a Window application you will need to ensure you have the correct paper size (ie 13.6 inch wide) selected in the Application AND the printer driver.
If you are sure the print data is wider than 80 column and the printer menu is set to 136 column and you still are not able to print wider than 80 column it may be necessary to reset the device back to factory settings. (Before doing this I would recommend printing the current settings or make a note of the current settings as you will need to set the device back up again)
To reset the device to factory default;
  1. Start with the printer powered off
  2. Hold down the four grey buttons under the LCD
  3. Keep the four grey buttons held down and power the printer ON
  4. Keep the four grey buttons held down until you see 'Loading Default' of the printer has finished initializing.
Once you have done this you should be able to print 136 column prints.
If you can not I would suspect the data is not greater than 80 columns in width and you would need to check the computer system set up.
Apr 24, 2014 | Tally T2250 Matrix Printer
Panasonic kx-p3626 Driver in window 7
We recommend you use the below link to review all available drivers and software.
Mar 06, 2014 | Panasonic KX-P3626 Matrix Printer
Connect panasonic kxp1624 to usb port
from panasonic.net. The drivers are already included in Windows 7 so you use these drivers manually when you install the printer to your computer :)
KX-P2624Use EPSON
LQ Series 1(136)
INBOX Driver*1Use EPSON
LQ Series 1(136)
INBOX Driver*1
May 18, 2012 | Panasonic Kx-p1624 24 Pin Printer Kxp1624...
Prints some letters incorrectly
because of mixing in foreground in background
but as per your problem is concern it is because of wrong printer driver processing
Mar 16, 2012 | Panasonic KX-P1695 Matrix Printer
We have installed window 7 but there is no driver for window 7
The drivers on your old OS can run on windows 7. Or you may download video, sound and other drivers compatible with windows 7.
Feb 04, 2010 | Panasonic KX-P1695 Matrix Printer
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website: http://panasonic.net/pcc/products/printer/windows_compliance/windows_xp_sp2.html
Ron
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Mar 16, 2009 | Panasonic Office Equipment & Supplies
555 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
