Question about Oreck Sanapathic DMS2000 Handheld Steam Vacuum
Oreck Sanapathic DMS2000 Steam Cleaner Stopped Working
I may have left it on too long allowing it to overheat causing electrical damage.  It served me well for several years and to outward appearances remains in excellent condition.
I fill the water chamber, plug it in, let it warm up for several minutes and press the thumb switch.  The internal steam apparatus makes the usual noise but no matter how long I hold down the thumb switch, no steam is generated.
Should I replace the unit, or is there a simple fix?
SOURCE: I have the Oreck Sanapathic DMS2000 Handheld Steam
ORECK DMS2000 No Steam
First, tested tank and filter flow together using suction via
plastic tubing. Worked freely Second, removed pump
and disconnected hoses and terminals [watch location,
three terminals on pump, two plugs]. Pump has a slug inside
and I could blow water either way. Sucked white vinegar
both ways until check action returned. Use distilled water
in future!
Posted on May 04, 2010
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
Water heats up but no steam comes out
Make sure the nozzle where the steam comes out is not clogged. Minerals in tap water may clog it cause it's very small opening.
Sep 03, 2013 | Oreck Sanapathic DMS2000 Handheld Steam...
Parts
check heater coil & hand switch.
May 28, 2012 | Oreck Sanapathic DMS2000 Handheld Steam...
I got it and I cannot figure out how to work it because I did not get an owner's manual. I need one.
Hi Chat: Sorry it has taken so long to answer. Have had problems with my computer and have been travelling. I have been able to locate your manual and have temporarly posted it here.
Please let me know when you have downloaded.
Thank you for using FixYa!
Mar 05, 2012 | Oreck Sanapathic DMS2000 Handheld Steam...
I have the Oreck Sanapathic DMS2000 Handheld Steam Vacuum, but no steam comes out when I push the button. I hear the motor, is there any buttons I am missing or any help on how to make it work, been...
in future!
Apr 26, 2010 | Oreck Sanapathic DMS2000 Handheld Steam...
Sanapathic
do you not have instruction book opration guide?? to make steam you req water then a method of heating it thus produce of steam results and pressure which expels via a nozzle ? just like the electri kettle
Oct 19, 2008 | Oreck Sanapathic DMS2000 Handheld Steam...
Motor and Lights stopped suddenly after vacuuming the stairs.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19809&thid=745467
Motor and Lights stopped suddenly after vacuuming...
Posted by Brigham81 on Jul 05, 2008
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse? Thanks, Brigham
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL2200 Bagged Upright Vacuum. It sounds to me that when the lights go out and it stops working that the motor is bad that you would have to replace the motor. It is still cheaper to replace the motor than to purchase a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck Sanapathic DMS2000 Handheld Steam Vacuum Logo
87 people viewed this question
Top Oreck Vacuums Experts
Roger Potts
Jim Parker
Jim Parker
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
