Question about Cyber Acoustics CA-2016 Computer Speakers
Distorted speaker sound
My speakers have sound coming from them, but the sound I hear is greatly distorted. This problem happens on and off, more often than not. Sometimes when I unhook the speakers for a while and rehook them, I can hear the sound just fine but that's very rare. I've checked the connection between the speaker and my computer multiple times, making sure it's properly connected. I've even gone as far as to find the manual and read it. Nothing in there gives advice about speaker distortion.
  • Anonymous Mar 28, 2008
    I think these are just cheap speakers? Most times the sound is greatly distorted. Low volume or mid range, it doesn't matter. Voices come through clearly during advertisements, but the moment music starts, it gets very fuzzy and distorted.
    D. Neeld
    3/28/08
  • Karmageddon May 18, 2009
    My speakers work fine most of the time, but often they have this horrible static-like distortion.They don't do it when my headphones are plugged in though. Sometimes if I touch the chord and place it a certain way, the noise stops, but it doesn't last long. It mostly happens when I listen to music, or when I use Skype.
  • Cyber Acoustics Master
  • 5,683 Answers
It might be that you have a bad solder joint somewhere. Try shaking the speaker when playing, but be careful not to short the speaker wire connections. If it returns to normal at any point this is a dry joint somewhere.
Posted on Jun 02, 2017
SOURCE:
PcExpert
  • 293 Answers
SOURCE: I have an IMac and cannot seem to get sound...
Is the power On? did you test them in the store?
Posted on Sep 14, 2007
  • 619 Answers
SOURCE: Speaker has sound when powered .
Hi , open the control panel /select to classic view,select add hardware to locate some drivers cyber acoustics speaker just follow the instruction to connect the speaker.
check also the device maneger the connection of the device.
Posted on Jan 12, 2008
SOURCE: computer speaker installation
I may have disconnected them and I need the disc to download so they will work- they worked earlier today and now they do not
Posted on Sep 29, 2008
hk_danni
  • 67 Answers
SOURCE: connect speakers to laptop
If the speaker you want to connect is from other devices(not a computer speaker )then you need an amplifier .Connect the speaker to the amp. then connect the laptop(output) to amplifier (input)the cable you need is "dual RCA male to 3.5mm male audio" .here is the link to view the cable that you need.
http://www.cablesnmor.com/rca-mini-stereo.html
Posted on Jan 30, 2009
RyanFanMan
  • 342 Answers
SOURCE: Connected new CA-2014 speakers to
you may need to check the sound card on your system if it is not showing up then you may need a new driver, or the volume is on mute
Posted on Mar 20, 2011
Sound very distorted, new motherboard and speakers fitted.
If the sound is distorted on all sources over both speakers then the speaker amp on motherboard is suspect. To eliminate bad laptop speaker possibility, try hooking up another audio source to the audio output of the laptop and hear what happens. If they also sound bad then the mo bo is definitely the culprit.
Jun 12, 2015 | Computers & Internet
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Distorted sound on the CA-3550
It could be that, or it could be that you have the wrong audio settings. Such as the quality of playback being set too low or a sound setting which is not for music.
Dec 30, 2017 | Cyber Acoustics CA-3550 Computer Speakers
Distorted speaker on nokia 7610 supernova
Ok there is only one solution, Just change the speaker (Ringer).Contact your nearest mobile repairing shop.Thanks for visiting fixya
Jun 18, 2012 | Nokia 7610 Supernova Cell Phone
Putting Speakers in Door Dont Know how to wire them correctly
Wiring speakers with reverse polarity doesnt have adverse effects. It cant give distorted sound. Seems like the wiring from the head unit to the speaker might be at fault. For testing purposes, connect the speaker directly to the head unit, bypassing, the car wiring. If the sound comes out alright, you have to replace the car wiring. If it is still distorted, speaker might be at fault. Try with a different speaker.
Oct 20, 2009 | Pioneer TS-G1642R Car Speaker
Distorted sound.
You can try shutting off Audio Hardware Acceleration.
Start > Control Panel > Sounds and Audio Devices > Advanced (Under Speaker Settings) > Performance.
Let us know
Good Luck
Apr 14, 2009 | Audio Players & Recorders
Inspiron 530 sound distortion
What kind of integrated sound card do you have?? I am going to assume its realtek. Go to control panel, then open up RealTek HD Sound effect manager and make sure the drop down menu for Environment is on "none". The try your speakers.
Mar 25, 2009 | Dell Inspiron 530 Desktop Computer
Altec lansing speakers series 100 plugged in but sounds are distorted
I have to turn the volume to max to hear any sound. Up until now the speakers were great and only needed to be turned on slightly? any suggestions please?
May 07, 2008 | Altec Lansing Multimedia Computer Speakers
Sound Distortion
somekind of hardware side failure or bad drivers.
I hear sounds from my audio output if i connect my headphones there directly but when I connect it to my speaker system they filter the distortion.
Apr 13, 2008 | ASUS M2N-E SLi Motherboard
Distorted and crackling sounds
please check sound using external speaker.
if the result is same as using internal speaker, it's mean your mainboard may have problem, but try to install sound driver first.
if the result is different, you may have some loose screews inside your laptop and it stuck on internal speaker.
if you still have warranty, send it to acer.
Apr 12, 2008 | Acer Aspire 5610-4648 Notebook
Cyber Acoustics CA-2016 Computer Speakers Logo
251 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Paul Bade
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
