Paloma tankless water heater won't stay on during operation.
I have a propane tankless heater and recently, after about a year of top service, it will not stay on. When you ask the unit to start up & run, after a few minutes, it will shut down completely. You can turn the unit back on but, the same thing happens again & again. What could be my problem ?
  • 3 more comments
  • Anonymous Dec 01, 2008
    i have apalma 74pv propane that starts up then cut off
  • jglurker Jan 01, 2009
    My Paloma tankless water heater just started doing the same thing last night. It will run for a few minutes and then cuts off.
  • Anonymous Jan 13, 2009
    We too have the same problem and after research from the plumbing company, it turns out Paloma sold some units with bad circuit boards. After 3 hours and $300, our plumber finally figured it out. Paloma apparently knew some of the units had bad boards but didn't know which ones. We're getting a new unit installed and also going to speak with a Paloma representative about getting some of our money back.
  • te3d Jan 22, 2009
    Has been shutting off recently during showers code C813 shows up. Any clue
  • J L Henager Apr 18, 2012
    Same problem. Runs for about 90 seconds, then stops running with a C8 13 error code. We turn off the unit at the remote, turn it right back on again, and get another 90 seconds of hot water. Paloma model PTG-74PVP-2, installed in September 2006. Worked flawlessly until Oct. 2011, when it began to fail occasionally, with either a C7 13 or a C8 13 error code. Now it fails each time the hot water is run for 90 seconds, unless the plumber is present. The unit is "covered" by American Home Shield's "warranty". They have sent 4 different plumbers since last October (they 'rotate' plumbing companies) and each time they have had to call Rheem, the company that purchased the original manufacturer (Paloma). The first time, Rheem told the plumber that there was no such error code possible, so he left without fixing it because it worked perfectly while he was here. The second time, Rheem told the plumber it was a propane problem, and he left without fixing it, since it worked perfectly while he was here. The third time, Rheem said the propane supply line was too small, and needed to be replaced. We had a larger supply line installed (tore up the walls and ceiling in the garage), but it continued to fail, but much more frequently. They tested the pressure (11 inches of water column) and flow rate (199,999 BTUs/hour), so we called for a plumber for the 4th time. Rheem told this guy that the flex line was restricting the propane flow, so he replaced it with a one inch flex line. AHS refused to cover the service call and flex line, because the problem was caused by an "improper installation". Apparently, the installation decays and fails after 5 years of use? On each of the 4 service calls, I told the plumber that, based on my own knowledge of electronic control systems, that I believed the problem was most likely caused by a dirty or defective combustion sensor in the unit. Each time, the Rheem "expert" dismissed the possibility of a sensor malfunction, and told the plumber not to "waste his time" disassembling the unit to clean sensors. (The unit has several sensors: combustion detection, temperature, gas flow rate, water pressure and fuel mixture ratio). At this point, I'm thinking maybe a class action lawsuit, with the purchasers of this pile of junk as plaintiffs and Rheem as the defendant, might solve the problem (or at least compel Rheem to provide schematics, test points, diagnostic information and cleaning/repair/disassembly/reassembly instructions). I think that would be fair and reasonable.
I have a Paloma model RUTG-74PVP, I had the same problem after less than a year. The unit would operate for about 90 seconds and then shut off with an error code of C13. Paloma kept trying to blame it on "lack of combustable oxygen" ,, my unit is in the attic, so we added more soffit vents and an electric attic fan. We still had the problem and Paloma blamed it on the lack of a condensation trap (so I added one), & then on the 1" dedicated LP Gas line (so I had the propane guy come run a water column test). Finally, 4 months later , Paloma had a service man come down (100 miles away) to see what was wrong (He told them to replace it. They paid for the unit and labor. It ran perfect for about 9 months and then started doing it again. So I called the same representative and asked if they were gonna replace this one too? He said nope, it's no longer under warranty. But he did tell me how to fix it this time. It required taking the the whole unit apart and cleaning a ceramic piece in the very back of the heater. It was hard to get to, and it took about 2 hours of disassembling and reassembling. The good news is Paloma will walk you thru it on the phone and once it's was done, my system worked properly again. The bad news is,, it only lasted for about 9 months. So now I need to do it again. I'm hoping that someone will read this and tell me that there is a filter (like a gas filter) that I can install that is easier to get to.
Posted on Jan 31, 2010
I have a paloma ph6dp water heater that hasn't
You have an old tankless computer and it won't work?
What would you do if you had old laptop computer that didn't work?
Copy following links for possible resources including required yearly maintenance so tankless computers can last 4-6 years before needing replacement:
Sep 07, 2013 | Water Heaters
Error code C7 13
Before calling service technician, open following links for troubleshoot resources including Rheem chat, and Rheem contact, and possible product manual:
C7 13 might be bad flow control valve.
While the tankless is down, I suggest also catching up on general maintenance such as cleaning the combustion chamber and burner parts, checking vent drain line, and cleaning water filter, and de-liming the heat exchanger.
Some resources are shown following pdf:
Sep 23, 2011 | Rheem Paloma Tankless Water Heaters...
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
My paloma is not heating the water. what could be the problem?
Check following link for Paloma error codes:
Check following link for recall list:
As general rule, tankless repairs are done by someone trained and certified by manufacturer.
This is because tankless are complicated and problems range from water quality, water pressure, air quality, venting, burner maintenance, sensors for each of the parameters listed above, and can also be a combination of factors.
Feb 22, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
I'm tired of my tankless water heater after two years. We can't get it to stay on more than 30 seconds. I've taken it apart, and it is clean. Had a service guy come out and he offered to clean it for $228....
ok code 11 is a gas issue... i would take a guess that you dont have a 3/4 inch gas feed, from the meter to the unit, and if you home gas furnace is close to the unit. I will also take a guess, that you did not have the problem during the summer
am I close.....
Dec 24, 2010 | Rheem Paloma Tankless Water Heaters...
What does C2 11 error code mean on my Paloma Tankless Water Heater.
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. However, if you're fairly capable, they will email you a step-by-step process on how to solve the problem yourself. They'll provide assistance through the process over the phone as well.
Sep 19, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Heating & Cooling Logo
1,261 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
