Question about OKIFAX 5950 Plain Paper LED Fax
Sender Id When I send faxes the sender id prints the number I send it to instead of the number it comes from. What do I have programed wrong?
  • 32 Answers
Sender ID Sender Id - ecblank.gif dot.gif ecblank.gif This is a descriptive title that identifies the sender -- usually the location of your fax machine or the name of your company or office. It is printed at the top of every fax you send. You can enter up to 32 characters. The first 16 characters will also be used as your Personal ID, which may appear on the displays or reports of other fax machines you are communicating with
Setting the TSI/CSI and Sender ID ecblank.gif dot.Sender Id - ecblank.gif ecblank.gif1 Press Menu/Exit to enter the menu.
2 Input speed access number 02. 3 Input up to 20 numbers and characters (0-9/Hyphen/ Space/+), press Enter. 4 Press Menu/Exit.
Posted on Feb 12, 2008
We have a FAX-2820. this is a dumb question, but does the fax header line come from the sender when we are receiving the fax? Does a header go out on any fax we would send out?
Yes, The fax header should show you who sent the fax to you. Every fax is supposed to have a terminal ID (senders fax number and Name)
Andrew
Sep 22, 2011 | Brother IntelliFax-2820 Laser Fax
Fax reception fails
Hello Dear,
The error message 242 appears in HP Photomart C7180, when the remote machine (the fax machine at Fax Sender side), is having problem, and it is trying to receive fax instead of sending. So actually both these machines try to receive the fax at the same time.
On many fax machines it is possible to accediently initiate the fax reception when:
1. The paper is not loaded in the machine
2. Or The paper is not correctly loaded.
You may contact the fax sender to check the above things. There is absolutely no problem with machine at your end.
Thanks
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
When receiving an RX Report can't see the senders details
If you are paying for caller ID it can show the sender but only if the sender is not blocking caller ID. There's no way to go back and get that info.
Nov 27, 2009 | Office Equipment & Supplies
How do I set caller ID to view on phone
Fax machines don't have caller ID, they only read what the sender has programmed into their fax machine. Such as NAME & fax number
Jul 22, 2009 | Sharp Office Equipment & Supplies
Tx image set not to display
getfile.asp?rid=1258 September 11, 2008
getfile.asp?rid=3215 Product : imagePRESS C1, All Fax Capable imageRUNNER Models Title : Setting the TX Terminal ID print options Question :
What are the options to print the TX Terminal ID on received pages?
Answer :
The TX Terminal ID settings enables you to specify whether the sender information is printed at the top of every document that you send via i-fax. Information such as your i-fax address is printed, enabling the recipient to know who sent the document.
Note: If you set TX Terminal ID to 'On' you can also set the position of the Terminal ID information which is printed on the recipient's paper.
The default settings are:
TX Terminal ID: On
Printing Position: Outside
Display Destination Name: On
1) Press Additional Functions
2) Communications Settings
3) TX Settings under Common Settings.
4) Press the up or down arrow keys until you see TX Terminal ID
5) Select On or Off
If you select ON:
Select the printing position of the Terminal ID information, select 'On' or 'Off' for display Destination name, press OK.
Printing Position:
Inside: The Terminal ID information is printed inside the image area on the recipient's paper.
Outside: The Terminal ID information is printed outside the image area on the recipient's paper.
On: The destination's name registered in the Address Book is displayed in the Terminal ID information.
Off: The destination's name registered in the Address Book is not displayed in the Terminal ID information.
If you select OFF
Press OK
6) Press Done repeatedly until the Send Basic features screen appears.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
May 05, 2009 | Canon imageRUNNER C3200 Copier
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Jun 29, 2008 | Brother IntelliFax-2820 Laser Fax
Manual Doesn't Work Either!
Fax machines usually don't have Caller ID. If you see the phone number on received faxes its because the sender has programmed it into their fax machine.
Jun 16, 2008 | Brother IntelliFax-2820 Laser Fax
Intermittent problem of faxes not being rec'd from various areas
After a detailed discussion on chat, we got disconnected before accepting payment. This is not a problem with your fax, as it seems to be receiving most calls fine. I suggest printing out a report - Menu/Set, 2, 0, 2 - of caller ID history and having the phone company look into it further. Either there is a problem with your phone line, or someone is prank calling your fax from outside of your caller ID service area. Both are problems for the phone company to fix.
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
OKIFAX 5950 Plain Paper LED Fax Logo
204 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
