Question about Intel Motherboard
Freezes MotherBoard GIGABYTE GA-8IE2004P when i work on my PC it's freez when ever I open more than one windows or specialy when I open Internet Explorer for mor than three IE window that is hapend when some graphic or picture In the internet site... but when I go bag to the BIOS and changing the CPU staf Like overvoltage or some change in DDram Staf .. then the broblem is (gone) but for 2 or 3 days ... I need to setUp BIOS Manualy (Load defult not working ..Load Failsave not working Others not ...) how to set BIOS with Information I send In the Picturs.. Thanx computersat@hotmail.com Ahmed Alwaqa'a
  • 983 Answers
I think the BIOS might have got corrupted if load default values are not working means ..
you can recover the bios by changing the bios jumper to the recovery mode ...
you can refer to your motherboard manual on how to change the bios jumper to the recovery mode it wil given with the labelled pictures ...
or can try upgrading your bios to newer version by downloading from your motherboard manufacture site which is compatible to your motherboard ...
if your windows is not working means then you can store that file in a floppy or cd and you can boot from that ..
there may also be some problem in the operating system so just reinstall the OS once before you do the above things ,...
any doubts you can reply me
regards
-Dileep
Posted on Nov 07, 2008
Installed win98.says welcome to windows 98 then stops.nothing further
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=1470#dl
Windows 98, in not a supported system.
So it will probably not run, on this mainboard.
Try with a smaller amount of ram.
Good luck
Sep 13, 2012 | Gigabyte GA-6BX7 Motherboard
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
GA-60MM7E Motherboard freezes on any operating system / harddrive / memory combination I try in it. It usually freezes early on (during or just after boot process). It is not overheating. Have removed...
Hi, you can download a manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=1506#manual
Try to change the harddrive with a new one
and make a new installation.
I think ist a harddrive failure because it not boots propely.
Does you get a blue screen when it does that ???
Sep 06, 2011 | Gigabyte GA-6OMM7E (GA-60MM7E) Motherboard
I have a Gigabyte GA-8IE2004P Motherboard now it is dead how to solve it.
Hi. a motherboard never dies. what is done is just replacement of Condensor. I preffer u talk to someone who knows how to remove and soldering again a new one with same type. Trust me. i've recovered more than 100 boards that way.
good luck
Nov 11, 2010 | Intel Motherboard
Gigabyte ga-8isxt-fs motherboard p4 2.6 i have
wow had the same problem....its not compatible
Dec 02, 2009 | Gigabyte Computers & Internet
Cannot update from XP Home SP1 to SP2 or SP3
start out with a xp home disc that has sp3 already Intragated on the disc - windows xp home SP3
Sep 03, 2009 | Gigabyte GA-K8VM800M Motherboard
AGP prob
just de-assemble the PC and again re-assemble it after dusting....then also tha problem goes on then contact me....+919665071117.... ashish
Aug 27, 2009 | Gigabyte GA-K8VM800M Motherboard
Two problems:1) Audio2) Freezing when running AMD Overdrive
format your hdd fat32 with xp geneuin. then setup motherboard driver...
Jan 08, 2008 | Gigabyte GA-K8N51GMF Motherboard
Intel Motherboard Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
