Question about BenQ FP731 17" LCD Monitor
BenQ fp731 monitor
Green light comes on but screen stays black, you say resoulder should fix it. can i do this, how? or , where do i get it done, and about how much will it cost me. im in canada... im not sure where you are but keep that in mind too. thanks.
    Problem Solver:
  • 7 Answers
Mine had a similar problem. Try shining a light on the display and seeif you can see (very very faintly) the BENQ logo when you turn it on.If you can, what you will probably need is this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220271974700
The description says that it is for Dell and HP monitors but I thinkthey use very similar components. In my case I only had to replace theBel 3a ms125v fuse and it's working perfectly now.
Sorry if you don't like eBay, but that was the only place that I could find those parts and the seller seems really helpful.
Posted on Dec 05, 2008
  • 153 Answers
The problem is something to do with the circuit board. Its the inverter cicuit that has one or couple of components faulty. I susgest you bring it o the repair shop. If you know how to check transistor II susgest you trouble shoot in the inverter circuit, there should be a transistor with a similar value to this (C5707) there you'll see two identical circuits. Check the transistors.
Posted on Nov 19, 2008
Black out problem
Try a different known working monitor and hook it up to the computer. Turn on the computer and the monitor and see if you can get video. If you get video then you know the original monitor is bad.
If with the known good working monitor you still don't get video then you know its something either with the video card or the motherboard if you have integrated video.
Jun 26, 2009 | BenQ FP731 17" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
Monitor displays breifly then goes to blank screen
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
BenQ FP731 17" LCD Monitor Problem
Connect it to another device, if you get the same result the backlight is bad! These can be replaced, but can be costly!
Nov 14, 2007 | BenQ FP731 17" LCD Monitor
Blank Screen Now.
Backlight is torched, it happens without warning. These can be repaired, but finding the appropriate backlights, and trying to get this thing apart is a royal pain in the you know what! But your backlight has burned out! Sorry!
Sep 30, 2007 | BenQ FP731 17" LCD Monitor
Bank screen now.
Problem normally is dry solder of power transistors and inverter transformer.Resolder should solve Intermittent or Display switch-off problems.
Samir
Benq FP731 17" monitor goes Blank after start up
Change the 2SC5707 transistors and electrolytic caps in the inverter
section. Also check the 3A picofuse, and resolder all transformer
pins
Aug 09, 2007 | BenQ FP731 - 17" LCD Monitor
Unexplained Blank screen.
Looks like your Power Supply has gone Kaput .. Usually it is the Electrolytic Capacitors on the Power Supply Board, try a new one, or replace ALL the Electros with same or better ones.
Jun 21, 2007 | BenQ FP731 17" LCD Monitor
BenQ FP731 Screen briefly displays then turns off
hi. i had the same problem and fixed it. the problem are the 4 transistors (C5707) one of more are shorted (Q739,Q740 and Q759, Q760). Also the fuse PF751 (3a) has to be replaced in most cases. In my case i replaced the fuse and 1 transistor (C5707)
Dec 06, 2006 | BenQ FP731 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
379 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
