Question about Frigidaire Refrigerators
Water Dispenser with mind of it's own
I have a 2 year old Frigidaire side by side refrigerator with ice and water dispenser on the freezer side door. The water dispenser will now, on it's own, shoot out approximately 1/2 to 3/4 a cup of water every other hour or so, the frequency is increasing.
  • paulvanwall Feb 08, 2009
    I have the same problem. I have purchased the Diode Kit #530391828 but nowhere in the manual or online have I been able to figure out where this thing goes. I would rather not guess and tear the whole thing apart. Is this in the door, up behind the ice maker, ??? How do I get to it?
    Thanks!
  • 725 Answers
One test is too turn off your ice maker and it will stop...you have a bad diode on the water line and are getting line feed from the ice maker...
to fix it you will need a new diode
#5303918287 DIODE KIT
#5304418384 DIODE KIT
the parts store will get you the correct one with a model and serial number of the refrigerator
let me know if it helps
Posted on Nov 03, 2008
I have a 16 year old Frigidaire Gallery Side by Side FRS20ZSH fridge/Freezer. We get water to the filter but not to the door dispenser or the automatic ice maker. Help please?
this could be one or two problems :
fridge door that dispenser is in is not shutting all the way any longer and the safety switch is not allowing anything to come out of dispenser , or the valves in the bottom of fridge are bad (16 years it's time to go too) these valves are not expensive and not hard to replace , just remember to turn water supply off 1st see your local or internet parts supplier to obtain them
Oct 28, 2015 | Frigidaire Refrigerators
Water and Ice Cube Dispenser not working
Water supply problem most likely. Check inlet solenoid and filter
May 15, 2012 | Electrolux Refrigerators
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser and Ice Maker
it might be your selenoid that closes the ice door in the chute but the water thing is says another thing might be wrong if you need service call 562-688-3627
Oct 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Ice dispenser not working
Ice auger in freezer compartment not working. Common problem with GE side by sides I know of at least 3
Jan 21, 2008 | Amana ACD2232HR Side by Side Refrigerator
Water dispenser
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Nov 27, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
201 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
