Make sure that you are using the right Guage wire for that installation. I had the same problem with another amp. I changed both, power & ground wires to 4 Guage and it worked fine after that. maybe that would work for you.
Was this solution helpful? Show your Appreciation by rating it:
this is a power handling problem, try to see if u have good power supply, a higher current may be needed. try to look for the impedance of your speaker, low impedance would load the amplifier that would cause on and off specially if it has overload protection.
