Question about SanDisk Sansa e250 MP3 Player
After computer crash doesn't reconize
I just formated my computer b/c it crashed and now it won't reconize my sansa e250 like it use to i tried it on another computer and it worked so its something with my computer is there another driver i can dl to fix this or do i have to re format
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
My 8GB Sansa seems to have crashed
Hi.
You need to update the Firmware of your Mp3 Player.
To do that try to follow this guide:
Sansa e250 MP3 Player Updating Firmware Guide.
Good Luck.
Nov 03, 2009 | SanDisk Sansa e250 MP3 Player
Songs dissapeared!
Several things. 1. To correctly reset it, flip the lock button, then hold down the power button. 2. Format your sansa. Make sure you have all your stuff off. Then, format it. If you don't know how, e-mail me here : spazzysmash@gmail.com Then sync it back on!
Feb 08, 2009 | SanDisk Sansa e250 MP3 Player
Sansa crashed have white screen
I have a e250 also and it white screened. I could'nt shut it off. I just left it on overnight and 1/2 of the next day until the battery went dead. Then pluged it in. It Worked!!!!
Jan 19, 2009 | SanDisk Sansa e250 MP3 Player
Computer reconizing mp3 player
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Aug 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 computer problems
Try using Windows Media Player instead, and see if you get the same result. If it loads in Windows Media Player, then the problem is with WinAmp and not your Mp3 player. When you say it loads half-way, do you mean it loads half the songs and then shuts off? Is the Sansa running on low battery? WinAmp has some kind of update released in the past week - did you download the update, and then experience the problem? It's probably not this, because other users have had the same problem that you are reporting since at least Christmas 2007.
The following is an advice from another Sansa user, so I haven't been able to verify it myself:
"I have to have WinAmp open and a song playing then connect my player and then it will work fine. If I just connect my player then start WinAmp it crashes"
If all of the above fails, reformat your player and start over from scratch. Let me know how everything works out - this is an issue that not even the Sansa website seems to have an answer for.
-Tha Mp3 Doctor
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 crash
you can try a firmware upgrade if you go sundisk website
they will have to software for that
Mar 06, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
read your manual (the whole thing if you have to then maybe you'll get a better understanding on how to function the MP3 player) if you dont get it then repost your message again saying you read the manual then help with what ever you need and give even more detail on how the mp3 player funtions on the outside
Woods24
Jan 31, 2008 | SanDisk Sansa e250 MP3 Player
MY sansa connect 4gp crashes my computer
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
Sansa 1 gig mp3
Dec 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
