Question about Konica Minolta Magicolor 2530 DL Laser Printer
Konica magiclolor 2530 DL Fatal Error 1bh
My printer printed one page that was not properly rolled thru the printer and then displayed a Fatal Error: 1BH. What does this mean and how can I fix it?
  • roybad Jan 21, 2009
    I've got exactly the same problem with a 2490 printer
  • restmin Feb 12, 2009
    I have the same problem...
I have the same problem and I can see that the black "V"shaped piece is loose and sometimes keeps the cover from opening.
I can not see where to put the screw to fix the problem. Any suggestions?
Posted on Sep 21, 2009
  • 44 Answers
Basically the fuser is not operating properly. This fault can be caused by 1 of 4 things. The fuser itself, the engine control board, DC power supply unit or the fuser safety switch lever hinge. The easiest to check first is the hinge. Disconnect the power cord and remove the Left side cover. Beneath this is a boomerang shaped lever arm with a pivot in the middle. As this pivot is plastic it can break over time. if you can source an appropriate self tapping screw, this can effect a repair.
Posted on Apr 21, 2009
Fatal Error code 10H
C 0010H - Color PC drum malfunction.Check the motor for proper drive coupling and correct as necessary.Check the motor connector and the electrical board connectors and the mechanical transport drive components(gears,couple).
Apr 05, 2013 | Konica Minolta Magicolor 2530 DL Laser...
Model 2530DL - Fatal Error Code 08H - help!
Worcesterlad came up with this some time ago: it's not a solution but somewhere to investigate:
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely
Jul 14, 2011 | Konica Minolta Magicolor 2530 DL Laser...
I have a Fatal Error Code: 17H Can you help? It is a Magicolor 2530 DL color printer.
Check your toner cartridges, one of them is seized up. Remove all cartridges and turn the gear on the right side backwards ( counterclockwise) about 10 times and see if it turns smoothly. I don't know why but 90% of the time its the cyan that gets stuck.
Jun 11, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error 17H
If the machine is under warranty then take it back to where you purchased it, or contact konica minolta directly and push for machine replacement.
Nov 01, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal error Code 16H
It relates to the transfer belt unit, replace it
Jun 04, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
1,541 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
