Question about Cuisinart CPT-65 Custom Control Total Touch 4-Slice Toaster
Kohler 81100 Pressure-Clean Flushometer Toilet
My toilet is flushing with progressively less pressure. I have checked, plunged, and snaked the line from the toilet. The problem seems to be the toilet itself. Is there a way to re-pressurize the tank?
  • 3 more comments
  • cchaille Nov 20, 2008
    I have the same problem with the same toilet. I've snaked, plunged, etc to no avail... I've heard the 81100 was pulled and Kohler doesn't even have replacement parts... I am very disappointed about it!
  • ecksteinmax Nov 20, 2008
    I also have the same problem. No real idea what to do.
  • ECBar Nov 22, 2008
    I have same problem. We have the same system which is over 10 years old. Bought at Home Depot.
    Seems a shame to have to replace the whole thing when it cost so much in the first place, I hope someone has a solution. It is leaking some water into the tank holding the pressure unit. I am on home water syatem here and my water pump is running a lot to keep up with the toilet. Several flushes are required. Hope it don't blow up. I'm dis-apointed in Kohler for not backing up a product. I have had a little problem with it over years but was able to make a few adjustments on it and it seemed to be working pretty good but is getting worse.
    Ed Barlow
    edbarlow@comcast.net
    Wilmington Mass
  • Anonymous Dec 07, 2008
    I have four Kohler 81100 units. One has leaked water into the tank and the other will not flush. I will go back to the Kohler Distributer to see if they will stand behind their product. They chose the units for me when I aked to buy the best they have.
  • Anonymous May 07, 2009
    I have the 81100 pressure toilet and it keeps running after I flush it. I have to manually lift the top and push down the magnet every time. What can I do to stop this problem?
Hi DavidofCA
I am with the Kohler Customer Care Center. My name is Mike. My phone number is 920-208-4622.
If you still need help with this issue please contact me. Thank you
Posted on Nov 07, 2008
WHERE CAN I BUY KOHLER 81100 FLUSHOMETER REPLACEMENT SYSTEM
you are in the toilets and bidets catagory so go to a plumber supplier shop and ask then what unit will replace the item
Sep 23, 2016 | Kohler Home
Kohler toilet not flushing completely
You have a partial clog, as if someone tried to flush paper towels or something that shouldn't have gone in the drain.
Try plunging, first, then a toilet snake, or you may have to get a pro to pull the toilet off the floor and run a larger snake if it's further down...
Mar 12, 2014 | Home
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
Feb 18, 2013 | Kohler Persuade Two-Piece Elongated Toilet...
Kohler 81100 water keeps running into bowl
If it is installed correctly then due to age, the seal may be damaged.
Dec 12, 2017 | Home
I have a Kohler 81100 pressure flusher that came with the house when I bought it. Can I remove the pressure system out of the toilet tank and replace it with a regular flushing system?
As a general rule, no However contact Kohler, they may give you a discount on a replacement toilet, as there have been some recall issues.
Jun 05, 2011 | Home
My flushometer toilet will not stop flushing. The
Try checking the water pressure. If it has dropped too low then the valve will never re-seat properly. Ideally over 90 psi.
Apr 02, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
This is a commercial toilet with a g-2 sloan valve on top. The amount of water dispersed is fine, but there is something wrong with the throat of the toilet, I think. The drain action is somewhat slow...
The blockage MAY be beyond the length of the snake you used. Once I had a blockage that required 145 feet of snake. ALSO the vent could be plugged by any of several things, including wasp nests.
Nov 04, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Dec 26, 2008 | Home
Cuisinart CPT-65 Custom Control Total Touch 4-Slice Toaster Logo
2,125 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
