Kyocera FS 1118MFP 'Scan error' - wont scan to computer. Error code is 1102
  • Anonymous Mar 09, 2009
    FS1118MFP, scan to ftp error 1102/1103 allow.
    ftpserver works same logon values.????
3 Suggested Answers
anantakumarj
  • 330 Answers
SOURCE: error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
Posted on Sep 24, 2009
SOURCE: How to scan from Kyocera
There is a send button on the left of the control panel. after pressing send, use address book, and chose where to send to....obviously your address book must be setup first
Posted on Mar 15, 2010
How do I fix Kyocera fs-1118mfp which outputs only partial copy of any document. When making a copy only part is copied. Placed the original on glass.
check to see if all the lights are turning on as it tries to scan (do a scan with the lid up and nothing on the glass.
Possiby need to rplace the drum in the printer.
Sep 01, 2016 | Kyocera FS-1118MFP Laser Printer
What does it mean when I receive error code 1102?
To Repair (Error Code 1102 Kyocera) error you need to follow these steps:
Step 1:
Download the (Error Code 1102 Kyocera) Repair Tool
http://www.almuseo.com/download-repair?Error%20Code%201102%20Kyocera
Step 2:
Click on the "Scan Now" link
Step 3:
Then click on 'Fix'. The Fix is complete.
*File size: 1MB
Download time: <45 Secs
Aug 01, 2014 | Kyocera Office Equipment & Supplies
Kyocera fs-1118mfp may copier display error code C6020 please help forthe solution
Remove the fuser unit and check if the heater lamp, the thermostat and/or the thermistor are broken
May 11, 2014 | Kyocera FS-1118MFP Laser Printer
This error indicates a problem with user name, password or domain name. Username/Password or Shared Name/Folder Name. Domain name is not entered.
A complete list of kyocera error codes with description can be seen here:
Kyocera Error codes
Nov 07, 2013 | Kyocera Mita FS 3800 Laser Printer
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Code error 1102
The 1102 error code means that the login user name is incorrect or the domain name has not been entered. You may need to reneter the login user name, domain name and password.
Jun 07, 2010 | Kyocera FS-1118MFP Laser Printer
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
Mar 24, 2009 | Kyocera FS-1118MFP Laser Printer
How to scan from Kyocera FS-1118MFP KX printer. There is no button for scan. Please describe how to scan from Kyocera FS-1118MFP KX
Aug 25, 2008 | Office Equipment & Supplies
4,189 people viewed this question
jasbo
jasbo
