Question about Dell 1600n All-In-One Laser Printer
Open Heat Error
We changed the fuser unit out on this printer a few weeks ago. Now it has a "OPEN HEAT ERROR" on screen, that changes back and forth to "PC Print Pending" message. I have cycled the power and the error comes up right away. I have not looked at the fuser unit yet. I amgoing to take a look at the lamp and look for any fuses or even a thermal switch. Any other input would be appreciated. Thanks.
  • Anonymous Apr 03, 2008
    We just got and hooked up dell printer and right away we are getting an open heat error on the screen.. Is this a defect should I just get a new one or is it a simple solution.. Thanx Lisa
  • micheli Apr 22, 2008
    "open heat error" Is there a solution?
The thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Posted on Oct 27, 2008
My problem was that I forgot to plug the fuser back in - there are 2 connectors - one on the right and one on the left
Posted on Apr 09, 2008
You need to make sure the voltage of the fuser is compatible with your printer. It can bring up all kinds of errors aswell as a burning smell.
Posted on Feb 22, 2008
I was gettng dirty copies and a Dell Rep suggested I needed to replace fuser. Ordered a new one, installed it with Dell's help and the "open heat error" started up. We then put the old fuser back in and the same problem continued...."open heat error". I'm wondering if something else may be in play...I've unplugged, replaced and started over but none of it helps. Perhaps there is something that needs to be reset, etc when installing this part. I did not have this error until I installed the new fuser.
Posted on Oct 02, 2007
    Novelist:
  • 114 Answers
From the user manual: http://support.dell.com/support/edocs/systems/1600n/en/index.htm The following errors indicate there is a problem in the fuser unit. CRU Fuse Error [Low Heat Error] Heating Error Open Heat Error [Over Heat] Suggested solutions include: Unplug the power cord and plug it back in. If the problem persists, please call for service.
Posted on Sep 27, 2006
Have an exellent used HP 8100 printer in home for private and at-home work use. Replaced paper pickup-up assy less than 1000 pages ago, fuser six months ago. No other obvious problems. Just a couple weeks...
hi warren,
If you can open the printer and detach paper assembly a while then put it back firmly,then also the fuser assembly..see to it that no other particles or foreign materials inside the printer and all were aligned.
Hope it can give you idea.
mastergani
Jan 27, 2011 | HP LaserJet 8100 Printer
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
I have Xerox Phaser 7400 with an error 928 we changed the fuser 2 weeks ago now the error has come back
Error 928 refers to the fuser motor failing. Problem could be with fuser motor, motor drive board or engine board.
One other possible cause would be if you are sending too thick a card stock through the machine, this can cause drag on the fuser which the machine interprets as a motor failure.
Hope this helps.
Jan 05, 2011 | Xerox Phaser 7400/DXF Laser Printer
Led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
Apr 24, 2010 | Samsung ML-2855ND Laser Printer
My Dell 1600n Laser Printer gives message Open Heat Error
Just call Dell Tech support. It's in their policies that if you call them and complain about a heat issue, they'll replace the unit for safety reasons.
Cheers.
Dec 07, 2009 | Dell 1600n All-In-One Laser Printer
50.1 fuser error
Fuser error is the high voltage drum. Normally there is a blown fuse somewhere attached to it that gives the error other you could have a defective fuser unit. Dont attemt yourself it works with very high voltages +- 600V
May 12, 2009 | HP LaserJet 8150n Printer
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
50.2 Fuser Error
Try to reinstall fuser ***'y, located in the back of the printer.
Whem this not solve you're problem you've to change the fuser ***'y.
p.n. RG5-7602 110-127 VOLT or RG5-7603 220-240 VOLT
Apr 12, 2008 | HP LaserJet 2840 All-In-One Printer
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
8,788 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
