Question about Sharp AR-5316 Advanced Digital Imager Copier
New Copy Machines do not copy. Blank piece of paper comes out.
Ricoh Aficio MP 1600 Copy Machine
Sharp AR-5316E Copy Machine
Both of these machines did not copy from the first time we tried them after buying them new. When you push the copy button, a blank sheet of paper comes out with nothing on it.
  • craigbadon Nov 03, 2008
    we have replaced the toner cartridge with one from our other unit that is working and still nothing. we have everything we can think of. Has anyone had problems with a new copier not picking up the toner? Is there anything we can check or clean?
    thanks for you help.
  • craigbadon Nov 04, 2008
    Can you give me a website that I can find a Users Guide for troubleshooting for a Ricoh Aficio MP 1600 Copy Machine.
    Thankyou
  • 6,487 Answers
    President:
  • 1,952 Answers
Http://www.ricoh.co.uk/KBase/index.cfm click this link
select ur model ur solved problem
Posted on Nov 03, 2008
    Genius:
  • 1,142 Answers
Hi
Please refer to this site this has the instructiion manual which you can download and refer to the troubleshooting guide.
www.sharpusa.com/files/cop_man_AR5316.pdf
Regards
Maanita
    Master:
  • 505 Answers
This no-print issue seems to be pervasive issue. Follow the steps below:
(1) Turn off and unplug printer.
(2) Open the left cover (this is the door where you put the toner cartridge in).
(3) Remove the toner cartridge.
(4) Using a flashlight, you will be able to see a small rectangular flap or shutter that sits just behind where the toner cartridge normally sits. The shutter might be about 3 inches long and one quarter inch high. I don't know for sure, but I assume that this is the "laser scanner shutter door" referred to by Colbert.
(5) Take a flathead screwdriver and GENTLY insert it beneath the shudder and GENTLY move the shutter up. When you do this there will be some resistance and the shutter seemed to be stuck. Move it up and down a couple of times and it seemed to move easier. Also follow the shutter door over to the right and up a little, where you can sort of see where the toner cartridge arm connects to the arm that opens this shutter. Gently manipulate this arm a couple of times with screwdriver as well to try to make sure it was free.
It only takes a few minutes and it should work
Good luck.
  • Indrajit Roy
    Indrajit Roy Nov 03, 2008
    If the copier is barnd new and still under warranty you can try contacting there technical support.
    Thanks
    Guru:
  • 859 Answers
Did you unseal the toner cartridge? Is comes this way to prevent toner from leaking during shipment.
Ask using the Text Area Comment box below if this was of no help and there is something else.
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Nov 03, 2008
    You may also want to shake up the toner carefully. It may spread easily outside the container, as the toner may have settled.
  • 849 Answers
Check the toner, is the toner has ready for use or its seal is broken for the use.
Reset method
try with new inkcatridge
Sep 03, 2014 | Ricoh Aficio Mp-1600 Copier
How to adjust Heat in Ricoh Aficio MP 2000l2
what problem does it gives when photocopy machine get under light.it that true it give dark on the top of the paper
Jun 20, 2013 | Ricoh Aficio MP 1600 Black and White...
My copier ricoh aficio mp 2000 makes a continuous creaking like an broken or consumed gear. what's the problem?
MP2000s often have creaking and squeaking issues. Typically it's the brass bushings that ride on roller shafts, so if you can isolate it to an area and clean and lube the bushings, you might be able to fix the noise.
Aug 12, 2010 | Ricoh Aficio MP 2000 Black and White...
When i copy o print a document, it comes out with tonner and black dust stains, how can i clean it? Ricoh Aficio MP 1600
a) If possible remove the drum unit and see if there is a paper stuck in the drum unit.
To remove the drum unit first open the front and right door. Then remove the toner holder(green lock).
Then pull the drum unit out from the front of the machine(press the lock).
b) How many prints(copies) has the drum made ?
The life is 60000.If it has crossed its life replace it along with the developer.
Feb 16, 2010 | Ricoh Aficio MP 1600 Black and White...
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
A new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
