Question about Rio Karma MP3 Player
Rio Karma freezing on startup. wont connect to computer.
When I turn on my Rio Karma it freezes on the opening screen. I cant even connect it to the computer to update the firmware or to even reset the player. Is there a way I can reset the player without connecting it to the computer??? Or is there anything else I can do to try and fix this issue... Any help would be great. Thanks. .smeff_jeff.
WoW! thanks a million, I had tried everything to fix my wifes RIO and nothing worked! hitting it actually solved the problem!!!!
Posted on Dec 16, 2007
I found this review on Amazon for the same problem, and it actually worked... I had tried hitting it before, but I had to give it a fairly good whack against the desk at the right angle before it finally started up again. "IF YOUR PLAYER GETS FROZEN AND WILL NOT GET PAST THE LOADING WINDOW TRY THIS. Several people (especially those who use their Karma while walking or running) have reported a particular Karma problem in which an hourglass appears and the Karma refuses to shut down. After resetting the device with a paper clip, it begins to start up, but only to a certain point - the Rio logo will spin fully, but the progress bar at the bottom does not move, and the text locks up at "Starting...". When holding the Karma to the ear, they report hearing a very quiet repeated clicking sound, followed by a beep every eight seconds or so. When trying to start the Karma in recovery mode, no text is displayed after "hdd:". These users have reported that hitting the Karma works very well in solving this particular problem. They suggest holding it in your left hand, with the screen facing you, Karma on the startup screen. Proceed to clap it into your right palm, so that the rubber grip hits your palm, hard enough to make your palm slightly red and to hurt a little. They report that this should set the Karma working again. If not, try slightly harder each time".
Posted on Sep 04, 2007
Have You tried inserting the end of a paperclip in the hole on the bottom?
Posted on May 14, 2007
The hard drive probably craped out on you
Posted on Mar 04, 2007
Poerick
I tried hitting it but it didn't work. I knew it was out of warranty, so I opened it.Was very easy to open 2 screws on the bottom, then slide the rubber part off. Then one more screw inside. When I opened it, it was very hot, but it rest itself. It works fine now. Try this if ALL ELSE FAILS...
Posted on Dec 03, 2008
Reset it with the hole in the bottom. Now connect it to your PC and format the hard drive. Check for HD problems from within the Karma. It worked for me twice already. Good luck
Posted on Jul 27, 2007
SOURCE:
After downloading a few games online, my computer been freezing up on me. It would freeze up 1 or 2 minute after i turn it on. I even tried to do a System Restore, but that would freeze up also. Even if...
Possibly a compatibility problem with software. Check your task manager for for new or unknown processes, and check your startup processes for such issues. Also scan your machine with an anti-virus and malware scanner.
Hope this helps, careful what you download, and always scan before opening.
:crabby186
Oct 03, 2010 | Computers & Internet
Why do i have to reboot 4 or 5 times to get it to work?
This is probably done to the bios on start up you will need to load new bios when you get connected
May 09, 2010 | Acer Aspire One PC Notebook
Rio karma hard drive
Hi. I use this adapter for RCA Lyra MP3 players and it could be the same for your Rio Karma. To be sure that it is a mini IDE connector, open the karma up by going here http://www.takeitapart.net/archives/rio-karma/ and if it is a mini IDE then you can go to Ebay and search for item # 230283935161. I hope this helps.
Aug 24, 2008 | Rio Karma MP3 Player
Rio Karma Battery
Try looking at Ebay item # 350057466979 or simply search for rio karma battery and you will find what you need. Replacing is as simple as taking some screws off and opening the rio. Don't have someone else do it because it is a simple thing that won't be worth paying someone else to do it.
Mar 17, 2008 | Rio Karma MP3 Player
Keeps Freezing
Welcome to the world of Microsoft Windows Updates - late 2007-early 2008. Ever since the mid-Novemebr Windows Updates, there have a been a rash of problems with players that worked just fine previously. The protocol before was that every mp3 player was an MSD or Mass-Storage Device. Now the protocol is that most players have to be a MTP or media transfer protocol device.
Try resetting the device by inserting a small #1 paperclip into the reset hole. Hold it in for a good 15 to 20 seconds - the player will shut off and then power up again.
When you say that the firmware upgrade failed, did it fail to upgrade the firmware, or did the firmware upgrade fail to resolve the freezing issue? I know for a fact that the firmware upgrade is good on the website.
As far as the computer not recognizing the device, I have often found that restarting the computer rather than the player will resolve the issue. In fact, I had more trouble with my Rio back in 2005 than I do now. In those early days, I was always restarting my computer over and over to get it to read.
Let me know if you have continued problems.
-Tha Mp3 Doctor
Feb 04, 2008 | Rio Carbon MP3 Player
Rio carbon
It sounds like there is a problem with the device firmware..update the device firmware and that should solve the problem you are having...
Jan 27, 2008 | Rio Carbon MP3 Player
HELP
Upgrade the device firmware and that should solve the problem you are having..
Can not copy files from Rio Karma to PC
Files can be copied to the computer from the karma although it doesn't work all that well.
You'll need to use Rio Taxi. I think you can get that if you connect the karma to your network using the dock then browse to the karma's ip address and get it. If not you may have to try and find a place to download it.
Nov 07, 2007 | Rio Karma MP3 Player
Rio Karma MP3 Player Logo
924 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
