Question about D-Link DGS-1008D 8-Port Gigabit Ethernet Switch (790069252747)
D-link cant accesed internet 4pc
Hi sir
i cant accesed internet 4pc ....? i can do lan 4pc .ip address 192.168.1.1 (server).how can i accesed net 4pc. my net BSNL broadband DSL modem.i accesed net by DSL BSNL Modem to D-Link Switch to My Pc (server)
 ( lan d-link switch 8 port ) OS:XP SP 2. plz sir ...........tell me
my email id krishvre@gmail.com
  • 1 more comment
  • krishna Singh
    krishna Singh Dec 04, 2008
    hi i can  do this process but user pc not conect net........?
    this process is right i do .........but when i format my pc i can't conect net other pc ...DSL modems are connected to switch and then conect
    pc server .............
  • krishna Singh
  • krishna Singh
    thanx
    Scholar:
  • 118 Answers
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Posted on Dec 02, 2008
  • tanvierahmed
    tanvierahmed Dec 04, 2008
    Okkk....
    if your DSL device is connected to the Switch it means you have DSL router.....
    Tell me one more thing.......
    All PCs are connected with the same switch??? Like Server and other computers...
    if Yes ...... Do the Following process on the server (where internet is working) n provide me some information retrieved from it.... so i can suggest you a proper solution.
    1. Go to start menu.
    2. open "RUN"
    3. Type "cmd" then press Enter
    4. a black Dos window will be open... here type the command "ipconfig"
    5. it wil retrieve some information .... from there tell me the following information given under "Ethernet Adapter Local Area Connection"..
    IP Address:
    Subnet Mask: 255.255.255.0
    Default Gateway:
    waiting for your coments..
    New Friend:
Hi sir
my email id rahulchore007@rediffmail.com
Posted on Jul 05, 2013
Testimonial: "Log on to the host computer as Administrator or as Owner. Click Start, and then click Control Panel. Click Network and Internet Connections. Click Network Connections. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up. Click Properties. Click the Advanced tab. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP address 192.168.0.1. Your computer may lose connectivity with other computers on your network. If these other computers have static IP addresses, it is a good idea to set them to obtain their IP addresses automatically. Are you sure you want to enable Internet Connection Sharing? Click Yes."
Let me help you,if you go by my advice than u dont have to make a server.first of all configure your bsnl modem,save your username n password in it.only after that you can use your modem for multi computers.after that,do lan networking,no need to write ip adresses,just click obtain it automatically.n you r done.if you find any problem,you can send your problem to sandhuravdeep@yahoo.co.in
Posted on Feb 09, 2009
I have a D link airplus xtreme 2100 AP Im set the option in LAN Dinamic DHCP, after that I cant conect trhougt browser, I used the Xtrem G AP Manager , IP address is 0.0.0.0 Net mask 0.0.0.0, I am...
Under Windows 7, press the "Start" button.
Type 'cmd' into the search-box, and press ENTER.
Type 'ipconfig /all', and press ENTER.
Look for the IP-address for the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Aug 24, 2011 | D-Link AirPlus Xtreme G DWL-2100AP...
My server has 2 NIC one of them connected to the router (ISP) and one of them is connected to the LAN.But DHCP and DNS working but there is no internet to the Host and also the server itself.when i...
This is more a configuration error. Depending on how you have your DHCP setup, you may need to adjust it's setting. No mention of what os you are using but if you set your DHCP to give IP addresses only to the LAN, set the ISP NIC address to receive its ip from the ISP provider, you should be able to get Internet access to your server and the LAN.
If you have done so, use the server os to setup your Internet connection. Answer a few questions about how you connect to the Net and the os will do most of the configuration for you.
Good Luck
C2Solutions
Jan 24, 2011 | Dell PowerEdge 1800 Server
Hi sir how can i change ip address for Dlink printer server DP-301P+
Logon to the Print Server web configuration and begin managing the DP-301P+, simply launch the browser (e.g. Internet Explorer) and type dlink-xxxxxx, where xxxxxx are the last six digits of DP-301P+'s MAC address. The MAC address can be found on the bottom side of
the DP-301P+ device.
Default IP Address of DP-301P+ is set as automatically getting from DHCP server or Router with build-in DHCP server. Please note that the PC's IP Address must be in the same subnet as the print server's IP Address for the two devices to communicate. (For example, if print server's IP
Address is 192.168.0.10, with a subnet mask of 255.255.255.0, then your computer's IP Address should be 192.168.0.x, where x is a value between 1-254, excluding 10.)
For additional information, please refer to Dlink printer server DP-301P+ Product Manual
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 11, 2011 | D-Link DP 301P (DP-301P) Print Server
HI, I have D-link DES 3026 manageable switch. i want to configure this switch.........In that we have to assign our IP....... I dont know how to assign the IP........ I have WAN IP, Subnet Mask, Gateway...
Normally most internal LAN addressing is carried out by a DHCP server which issues IP addresses to anything that is connected to the network.
IE your computer. most switches are set to obtain an IP address from them as a default. to find the IP address of youe switch you need to look at your DHCP server ( possibly your router/modem) and see what addresses have been issued. Once you have found the address it is a simple task to open your internet browser and type in the ip address of your switch. once there you should be able to configure your switch as per your requirements.
Jul 17, 2010 | D-Link Computers & Internet
I formatted my system and reinstalled Win XP on it, but now I could not use wireless to connect with internet
Make sure you have Wireless network adapter driver installed.
Manually assigned IP address and DNS address as earlier (if your IP setting is not automatically assigned by DHCP server).
If you are using router set your Router IP address as your Default Gateway Address.
If you are using Internet through a Proxy Server then Open "Internet Explorer ",
Click "Tools",
Click "Internet options",
click on tab called "Connection",
Click "Lan settings" Button.
Remove "Automatically detect settings".
Tick "use a proxy server for your LAN....."
Type the IP address of your Proxy Server and the port no.
It will work.
Dec 26, 2009 | ASUS A8HE-X1 Notebook
DP-300 Print Server Access Problem
Using a print server like this, you should not need to "browse" to find the printers. See what ip address has been assigned to the printer. Once you have the ip address, open a command prompt (start -> run -> cmd) and type:
ping <insert ip address>
ex: ping 192.168.0.24
See if you can ping the printer from each of your computers. If you can, great, install the new printer by adding a "local" printer at a new TCP/IP port with the IP address of your printer. If not, then you may have some routing issues.
Are all of the printers connected to the same switch? Do you have multiple "routers" on your network acting as DHCP servers?
Hope this helps.
May 27, 2009 | D-Link DP 300 (DP-300) Print Server
Sir how to dlink routter confeegur to one ip but iconfugger to other ip
The D-Link Router is a "DHCP-server" -- each computer that connects to it should be set to "automatically obtain IP-address".
Then, each computer will be assigned a UNIQUE IP-address.
Jan 19, 2009 | Cisco IOS Enterprise LAN Only 12.1(13)E...
Sharing internet to lan networking
dear sir
plese go to the following site to sharing internet to lan networking..
http://en.kioskea.net/contents/pratique/partage.php3
regards
murali
Dec 10, 2008 | Computers & Internet
D-Link DGS-1008D 8-Port Gigabit Ethernet Switch (790069252747) Logo
709 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
