Question about Maytag Performa PAV2200
No power-burn smell/smoke
I am trying to get the motor out..do I have to remove the outer tub?What's the easiest way? Is it worth replacing the motor?
    President:
  • 878 Answers
Billyjoe, you can remove the front panel, puddy knife on each side of the top front, the panel will lift out toward you. Now you can get a look at the motor and glides. If you tilt the washer back you can get a look at the belt and pulleys. You want to make sure that the motor is the problem before replacing it. Catriver..post back.
Posted on Sep 28, 2006
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Kenwood fpm800 stopped
Hi, Like any washer if you smell something burning and a humming from the motor I suggest you take out any cloths in it and try turning the inside basket clockwise to see if it turns freely and if it does then the motor is defiantly shot but if it won't turn freely then either something is jammed between the inner and outer tub or the transmission if it has one is bad or the bearing housing is bad so try and disconnect the belt from the motor and see if the motor runs and if it does then follow from the motor to the tub and see what is frozen .
Good Luck
Gynoman
Sep 13, 2014 | Washing Machines
I have a Kenmore Oasis Elite 110.280442700. I bought it at the beggining of 2008, never has given me any problem. About a month ago, it started to make a really loud noise during a spinning cycle, as if it...
April, You say you are suspicious that the smoke could have originated from the motor, BUT have you confirmed it? Have you tried running a short cycle without a load to see if the spin cycle rattles the machine or whether the machine works? Watch for smoke and turn off the machine immediately if you see or smell burning. If the motor is burnt, I think replacing should not be an option but rather replacing the machine should be considered.
Mar 01, 2014 | Kenmore 22642 Top Load Washer
When the machine goes into the spin cycle the tub barely rotates a hot burning smell slowly appears and when I turn the machine over and inspect it the clutch is extremely hot. Motor and gearcase are cool...
This could be something trapped between the inner and outer tub or even your bearings have collapsed.Get a torch and look inside the drum through the tiny holesnto see if you can see anything if there is something.you will have to remove the tub to pump hose to get at it
Jun 11, 2010 | Washing Machines
BURNING SMELL COMING FROM MY WASHING MACHINE
if it smells like rubber burning then i would suspect a belt is worn or slipping or somthing has jambed the basket from turning .. the belt is not expensive ..labor of course would be extra .. if the burning smells like insulation or a strong electrical burning smell then you may have a bad motor .. those used to be about $70 + labor .. no telling what they get for them now ...
you mention that the smell came from inside ... do you mean inside where the cloths are (the tub) or inside the cabinet (outside of where the cloths are) ...if the smell was coming from inside the washing tub .. then i would suspect something cought between the inner and outer tubs .. if the smell is not from there then the first suggestions above are good ... bras and slippers and such are good for getting cought .. check where the movable tub (with holes) meets the outer tube (no holes) .thats at the very top of the tub .. ..make sure nothing it cought there ...
Aug 05, 2009 | Washing Machines
Admiral lnc6760b71 Problems - Strong smell of burning plastic or rubber last week. Now the machine will stop when full of water and not respond. Later it will continue by itself. I took of a small panel...
Same problem, same model admiral. The smell is motor overheating. Once cool enough, it will continue with it's cycle. I took the top off and watched it run. The motor stopped and smoke rose from the motor located at the front right corner. I am scrapping mine and buying another washing machine. This admiral has been trouble since we bought it 5 years ago.
Jul 11, 2009 | Washing Machines
Washer was pouring out smoke and smelled liked burnt rubber
You most likelyhave burned a drive belt. Could be a couple things. If the machine was loaded to the max and a bit more, it is possible that a small article of clothes may have been flung into the outer tub and into the pump... this can freeze it up and the motor will keep trying to turn the belt against a frozen pulley.
You'll need to open the machine and check the pump for blockage and change the belt... let us know if we can help with procedures..
k
Jun 25, 2009 | Frigidaire FWSB5700DS Top Load Washer
Wahser stopped after wash cycle, burning smell
Hi, it is possible that something got into the pump and stopped it from turning. Let the drain hose down so that it drains into a bucket or a floor drain if possible.
If water does not drain then it is deffinetly plugged. Once you get the water out of the washer, tip it against the wall and try to remove the pump off the motor. There are two clips that hold the pump on. You will also need to remove the hoses.
With the pump off, you can set the washer back down and try to run the spin cycle. If the motor runs, it must be the pump.
Please let me know if I can assist you further.
Thanks
Vic
May 23, 2009 | Roper RAS6233KQ Top Load Washer
Leaking tub seal, slow spin cycle
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
