Fan runs but air conditioner doesnt
I have a 2007 kia rondo.Ac was working,parked it for a year,ac wasnt working,recharged,the ac,it worked for a month,an started again,blowing hot ai.If you let it set for hour would start working...then after a few days it would only work early morning,if you dont turn ac of,then it stop working,I see the clutch isnt kicking in,ir you try an put freeon in it soon as you start putting it in it would kick on.An its full of freeon.
SOURCE: air conditioner 2004 kia optima
CHECK AC COMPRESSOR CLUTCH FUSE AND RELAY.MAKE SURE POWER IS GOING TO COMPRESSOR CONNECTOR.IF NO CHECK FUSE AND RELAY.IF YES.YOUR PROBLEM COULD BE AC CONTROL SWITCH BAD OR BLOWER MOTOR.COMPRESSOR CLUTCH SHORTED OR OPEN.AC PRESSURE SENSOR BAD OR REFRIGERANT IS LOW.
SOURCE: 2003 Kia sedona a/c
Our Sedona had a similar problem, Turned out that the pipes to the rear heater had corroded and were leaking, caused some overheating which blew hot air when the A/C was on. I would check this then check the coolant pressure.
SOURCE: my kia spectra was making a loud squeeling noise
Look at the AC pump. See if the belt is there, slipping, or the pully clutch engaging.
The center of the AC pully can be standing still while the outside turns. There is supposed to be a magnet that grabs the outside and locks it to the inside when you turn the AC on. The magnet could be bad or its clutch slipping.
SOURCE: MY KIA FAN ISNT WORKING, SO MY HEATER AND AIR
Could be your blower motor is bad OR blower motor relay.
The burning smell could be due to gas leakage in the engine compartment. The gas smell is being sucked into the fresh air intake of the air conditioner. It can be avoided by checking either fuel pressure regulator or fuel injector.
