Question about RCA Lyra RD2763 MP3 Player
File Sytem Corrupted!
My mp3 player shows a errro message: "File System Corrupted!", and the PC can not detect the device, therefore I can not update the system files or/and format the hard drive. Thanks
    Problem Solver:
  • 5 Answers
The dreaded "File System Corrupted" error is one that comes time and time again. Did you drop the player or hit it by accident? If so, then the pin connecting the battery to the micro hard drive has probably been disconnected. You can removed the back of the player with a screwdriver, but you risk tearing off the S/N sticker. If you decided to do it anyway, remove the back of the player and then simply fit the multi-pin connector back into the hard drive. Replace the back and screw it in, and then turn it on to see if it works. I did this with my old RD2762A, and it worked like a charm. Hope this helps!
Posted on Aug 30, 2007
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
Hi, my mp3 player is not turning on. when i try to open it, the screen shows file system error
if your PC can show the removable disk drive you should format it. In this case all the folders and media files will be erased on your player.
If the PC can not see the player you could try to make firmware upgrade.
I think, this link will help you:
http://www.userdrivers.com/MP3-Player/Philips-GoGear-SA6015-SA6025-SA6045-MP4-Player-Firmware-Upgrade-1-15-2/
bye, gylacz
Feb 01, 2011 | Philips GOGEAR SA6045 MP3 Player
File system error: FAT is corrupted
Your hard disk on your media player is corrupted which also does happen on a normal PC/Laptop. To fix it, use windows explorer -> right click on your mouse againt the media player drive -> select properties -> select 'Tools' tab -> select Error checking / Check now -> Tick on 'automatically fix file system errors and recommended also 'scan for and attempt recovery of bad sectors' -> Start.
At this point, you may also need to restart your PC/LAPTOP and then be patient as 120GB is a fairly large drive to repair! Once the FAT has been repaired, depending on the corruptions, you may need to replace some songs, video, photos or other files.
ps. the other 'drastic' option is of course to reformat the whole Media driver drive !!!
Dec 18, 2009 | Archos 5 MP3 Player
My pc could not read the player therefore i could not open to view file what can i do
the player yp u2 when start 20% loading and still off.i ve trial to update my firmware but stil not detected it says please connect the device..i ve push play button....but still no detect ..any body can help me..
thanks
Nov 28, 2009 | Samsung YP-U2X Digital Media Player
When i hook my player up to the computer it say file system error
For sure, the file system is corrupted and is the cause of your woes. The fix lies with the Philips Songbird software. If you do not have Songbird, download it for Windows or Mac here: http://www.usa.philips.com/c/mp3-media-player/22126/cat/en/#/difference/philipssongbird.
Once you have Songbird installed, launch it and select "Repair my Philips device" in the Tools menu. Select your device and follow the instructions specific to your device. For example, instructions for the GoGear Vibe are to disconnect the device, power it down completely, and hold the volume-up key during and after USB connection until the message window disappears.
If the repair utility endlessly indicates it is checking for updates, you are likely using an out-of-date version of Songbird - probably the one that came with your GoGear. If this describes your situation, launch Songbird and select "Check for updates" in the Help menu. This will at least get you upgraded to version 1.9 (currently), even though the latest version is 1.11 (currently).
Instructions that came with some older versions for connecting GoGear in repair mode were incomplete. They left out a crucial step of turning off the GoGear and waiting for it to power down completely before reconnecting in repair mode. Newer versions of Songbird include the ability to reformat the device, reset the device, and to get progress updates during synchronization.
If you've found this information helpful, please indicate as such.
May 26, 2009 | Philips GOGEAR SA6045 MP3 Player
Message showing - player problem connect pc and fformat player
i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
Mp3 has crashed
Hi! When you repaired your mp3 player you formatted it with ntfs file system but your player needs fat32 file system. Don't be upset just plug in your mp3 player again with your PC and reformat it by changing the file system to FAT 32. Hope this helps.
Dec 30, 2008 | Philips GoGear SA3245/37 Digital Media...
FILE SYSTEM CORRUPTED MESSAGE
go to http://www.rca.com/digitalaudiodownloads/ and select your mp3 model and update the firmware.
Aug 17, 2008 | RCA Lyra RD2762 MP3 Player
..file system corrupted...
if you specify "corrupted" then i may be able to help what exactly happened?
Mar 01, 2008 | RCA Lyra RD2765 MP3 Player
My mp3 player restarts when it turns on
Connect the player to your computer and then reformat the player this is usually cause by corrupt songs in the device. If it the player is detected as a portabel device. Perform recovery mode onf the player then follow these steps. 1. Create a New Text Document in your desktop. 2. Open it and click on File then Save As 3. Change teh Save as Type  All Files and the file name is sansa then save the file. 4. Now copy the file to the 16 MB drive which is located in your My Computer. ****** This will format the player and delete all the songs in your device. If it did not work update the firmware of the player.
Mar 18, 2007 | SanDisk Sansa e250 MP3 Player
RCA Lyra RD2763 MP3 Player Logo
70 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
