Question about Intel Motherboard
New Motherboard Problem
Not sure if this is a new thing or not, But I recently upgraded to the MSI K9A2 CF-F Motherboard and new AMD Phenom X3 8650 CPU. Everything else is old and well tested to work fine. Now that I upgraded, I can not boot fully into windows. As in, It gets almost done loading windows and then reboots. All drivers are installed using Safe Mode and I am using Windows XP Home with Service Pack 2. Raid is seeing 1 of the 3 Hard Drives installed. Video card is fine and Ram is fine. Everything else is working fine just having a big problem with Windows rebooting on each and every boot. Not sure what to do about this. Please help!
  • sk5000 Nov 04, 2008
    Okay, I figured out the problem. It was the AMD Dual Core Optimizer I had installed, No longer needed it and windows loaded it anyways. I could not unistall it BUT I could take it OUT of the directory that it was in and dropped it onto my Desktop. Now windows boots just fine. Thank you for the update though.
  • 781 Answers
I believe you have a driver conflict
Check your BIOS is set for CPU etc.
And Uninstall all drivers And see if computer start with only the windows drivers present.
As if you have just installed windows and no M/board drivers.
And reinstall M/board drivers one at a time Should fix your problem
Posted on Nov 04, 2008
  • David
    David Nov 04, 2008
    I did say it was a driver conflict could you please give me a fixya thanks
Can AMD Phenom X4 9650 Quad to use in motherboard Asus M4A78T-E ?
Yes your motherboard supports AMD Phenom X4 9650 Quad. However you need to make sure your BIOS verson is greater than 1503. if not you need to upgrade your BIOS.
Caution: Update your BIOS if its absolutely necessary and at your own risk. Wrong move may spoil your motherboard.
Aug 18, 2011 | AMD 2.3GHz Phenom X4 Quad-Core 9650 AM2+...
I have a new AMD Phenom X4 9750 quad core processor with a new MSI 785GTM-45 motherboard and a aluminum CPU cooler fan 95 watt. when I try running the system it won't stay on for more than 45 seconds. I...
It is possible that the processor may be defective but that is very rare. Take the processor off of the motherboard and reseat it. Make sure that you are using thermal paste(preferably aluminum) properly. The motherboard has a function in it that if the processor overheats it will shut the computer down to prevent damage. Also check to make sure that you RAM is fully seated and also that it is compatible with your motherboard. I have seen several instances where the RAM was not compatible with the motherboard and the computer will not boot.
Mar 11, 2011 | AMD Phenom X4 9750 Quad Core Processor...
I bought a MSi 790gx-g65 mobo and an AMD Phenom II x4 940 which is am2+. Everything I've heard about this mobo is that it's am2+ and am3 capable, will the Phenom II am2+ I just bought work in this mobo?
Yes it will, but you'll need to update the bios to the latest one in order to be sure the processor is recognized. The 790 chipset will make that board an excellent performer with the Phenom 940. Give it as much dual channel ram as you can afford, up to the max of 4 gig for a 32 bit O/S or 64 gig for a 64 bit system.
Nov 10, 2009 | MSI AM3 790GX-G65 Motherboard for AM3/AM2+...
Problem with MSi K9A2CF mother board
More info on what happens from powering up your system and some of the devices listed you are using
Jul 22, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
How do i get rid of a blaster bug located in the bios , MSI k9a2 cf board without going on the internet with this computer,phenom 3 core proc, tried a antivirse software , nothing found, formated HD
Try using a good Antivirus software like McAfee, PCCilline, Norton Antivirus, NOD32 etc. First download the Antivirus and install then update it. In most cases such problems are solved. (ehteshamhusain@gmail.com)
Apr 21, 2009 | Computers & Internet
New PC shutting down with MSI K9A2 mother board
this is a problem complexing situation because here are involved more than one device that causing this, if you have time and parts to experiment is a good think, you have to take out from your board cpu ram and vga-s and put in their place a second component(take from your friend or if you know that guy in service maybe halping you with parts so even him is taking experience of this situations). after testing your Mb with second components if it working fine no shut downs no crahes, then problem is in one of other components, try it taking out second parts one by one eny time, replacing with your components. begin with vga(or vga-s if you have more than one but is better to put it and prove them one by one to diagnose if their have problems) after doing this and you didnt finded problem in vga/s let your part in place and change second ram taht you puted with yours(if have more than a module prove it one by one each time reboting system after each one.) if even in your ram you dont have problems, so change cpu/s. one of this components without dubt is faulty.
if problem resolved and you dont have more problems and didnt find a faulty component and your pc is working fine so it was a miss making.
try all experiments with mother board outside case. some time shrt circuit of Mb with case is causing problem, after try it in case if you dont finded problems, in any way that i told you up.
Apr 07, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Bios Beeps during reboot
According to the information at:
http://www.pchell.com/hardware/beepcodes.shtml
AMI beep codes of 1 long and 3 short are, in fact, correctly identified as memory errors. One thing to note is if this memory is Dual Channel, you can only install the memory in groups of two. You must first fill DIMM slot 1 and 3 before filling DIMM slots 2 and 4.
The below website has much more information about your particular motherboard and there's a note about some JEDEC setting for memory that you might want to watch out for or disable to see if it improves stability.
http://www.msicomputer.com/product/p_spec.asp?model=K9A2_CF-F_V2&class=mb
As for Windows XP 32-bit not recognizing more than 3.5 (at most) memory, this is unavoidable. To see all 8 GB, you would need a 64-bit version of Windows. This is something that cannot be altered by BIOS or memory choices, unfortunately. Feel lucky in the fact that you have XP Pro as XP Home will only recognize up to 2.5GB. You'll never utilize all 8GB unless you upgrade your OS, so keep that in mind!
Mar 04, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Detecting hard drives
try bios settings it may be set for a particular hard drive not yours and not on auto detect set for auto detect
Aug 02, 2008 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Intel Motherboard Logo
59 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
