Question about Nova Development Photo Explosion Deluxe for PC
Program keeps shuting down
When I first open up the program it asks me if I would like to register my product.. I have done so twice already and when I go back into the program and click Later, Never or even the x the program will just shut down.Also, when I was first installing a program I encountered one problem and dont know if this is related.. the error message read "INF.Install failure.. Reason: Access is denied." PEASE HELP!
  • YPantoja Nov 04, 2008
    Did that 4 times.. no luck =(
  • 102 Answers
It sounds like you are not set up with administrator privileges on your computer and are not allow to make changes to the system (ie: Install programs)
Posted on Nov 03, 2008
  • 1 more comment
  • Kenneth Crowther
    Kenneth Crowther Nov 03, 2008
    I would uninstall completely then re install. Be sure that all other programs are shut down when you install. Then reboot.
  • Kenneth Crowther
    Kenneth Crowther Nov 12, 2008
    You mught have too many cookies on your computer. But really it sounds like there is a scratch where that file is located on the disc. try going to the companies web site and check for drivers and updates.
    kcmetal9901
  • Kenneth Crowther
    Kenneth Crowther Dec 04, 2008
    please rank me
2013 Toyota Highlander. Key fob remote doesn't work after installing new battery. It is not a smart key remote.
PROCEDURE. Make SURE the battery you installed is good.
  • Driver's door open, key removed from ignition switch
  • Within 5 seconds: Insert and remove the key from the ignition switch twice
  • Within 40 seconds: Close and open driver's door twice
  • Insert and remove the key from the ignition switch. Close and open driver's door twice
  • Insert the key into the ignition switch and close the driver's door
  • Within 40 seconds: Switch ignition ON and OFF once to program a remote transmitter code whilst retaining the original codes or twice to program and remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitter are currently registered or five times to erase all registered codes
  • Remove key from ignition switch. System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered
  • Within 40 seconds: Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
  • Within 3 seconds: Press LOCK button
  • SYstem should now lock and unlock vehicle once to confirm registration, twice to indicate registration has failed
  • Within 40 seconds: Repeat button procedure to program remaining remote transmitters.
  • NOTE: To exit programming mode: Open driver's dorr
  • NOTE: A maximum of 4 remote transmitters can be programmed
If the above programming procedures do not work, then you should contact your locksmith.
Goood Luck!
Dec 13, 2017 | Toyota Highlander Cars & Trucks
Re register product
go on line for the program and when you get the exact one , press down load
at some point it will ask for the 25 digit code so use that from when you bought it
It should be on the package or case
if you don't have it ,ring the company technical service and they may be able to give it to you or a new one to activate the program
Jul 04, 2016 | NCH Software Photostage - Win
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
Nov 01, 2011 | 2004 Lexus ES 330
I have upgraded my pc to windows 7, I installed WebEasy 8, registered online and entered the serial, and now when I try to open WebEasy 8 I get the message "This programe has stopped working" and...
I am assuming that since you already registerred they have it on file. I would uninstall the program and reinstall. With the registration on file you can reinsall on the same computer with no problems.
Apr 07, 2011 | Avanquest WebEasy 8 Professional Full...
I just installed the program and keep getting error report that the program will not open.
have you restarted your computer, if yes you may need ti reinstall it but you also need a product key to activate and register it as well
Mar 20, 2011 | Avanquest My Invoices And Estimates Deluxe...
I am trying to update my garmin 255w and not getting anywhere. I have no idea what I am doing wrong. Help
To update the maps you connect the satnav to your computer. If you haven't registered your satnav already you need to do so first. Go to www.garmin.com. Select your country and then click on myGarmin. If your satnav is already registered skip to the next paragraph. If it's not registered click on Register Your Garmin Product. When registering you'll be asked to create a username and password. Write them down and keep them safe as you'll need them anytime you update your maps.
When you have registered your satnav, or if it's already registered, Click on myGarmin, enter your username and password and log in. Click on myMaps. If there's a map update available it will say so beside the map name. Click on Get Update and follow the prompts.
To update the software, connect your satnav to your computer, download and install webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 if you haven't already done so. When it's installed it will search for updates. Follow the prompts.
Aug 16, 2010 | Garmin nuvi 255W GPS Receiver
Hi I purchased CRE software on ebay...the software
You'll have to email or call the company support. Most companies are glad to assist in these kinds of situations.
Jun 21, 2010 | Pc America Restaurant Pro Express
Problems Trying to Run Program for First Time
administrator-right click on music creator and open as administrator.
click allow.
that all happend to me....so i called them and pitched a fit to the point
of them giving me all new codes. you can try thaT.
Dec 18, 2009 | Cakewalk Music Creator 4
Notebook keeps asking for product code
have u registerd it if not itll keep asking.
Oct 19, 2009 | ASUS Eee 4G Notebook
Am looking for product key for 2007 microsoft office
Is it already installed? If it is, then this program SIW(system information for windows) might work. If it isn't then it might still work. Ok after you have downloaded and installed it from this site:
http://www.gtopala.com/ ---- open the program and look on the left side where there are alot of options. Open the first tab the software tab (it might already be open) and go down to the seventh option which is the Licences option. Click on it and wait for about a minute or two and it will be done. After its done it will post all the keys for all programs already installed on you computer. At least it will post for the ones that actually need a key. Find the one that you need.
Jun 14, 2009 | Microsoft Office Professional 2007 Full...
Nova Development Photo Explosion Deluxe for PC Logo
59 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
