Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
My fridge isn't working...
It is pretty new, but seemed to go "off" and now it won't go back on again.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
I need to know what the model number is to help out. it could be three things. most likely it is the relay overload on the compresor. next i would check the cold control. less likly would be the defrost timer. if your not comfy with a multi meter I would call in a technician.
Cheers,
Todd
Posted on Nov 08, 2008
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Tip
My freezer compartment of my Daewoo fridge is cool (though not as cool as as it...
The fridge gets it cold air from the freezer. There is like an air tunnel that goes from the freezer (usually in the back) to your fridge to provide cold air.
What probably happened it the tunnel is blocked with ice or another liquid. The easiest thing to do is unplug the fridge for 24 hour so the ice can melt.
If that doesn't help, we will have to manually clear the debris in the tunnel.
on May 31, 2010 | Refrigerators
Frigidaire FRS26R2AW5 Refrigerator too cold on fridge side.
If the dampers are closing when you select warmer temp with the fridge temp control, there really isn't a way for the cold air to enter the fridge. Check to make sure the damper isn't opening back up after a while.
Feb 29, 2012 | Refrigerators
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
RS265LABP freezer works but fridge doesn't.
if the evap fan motor isn't running then most likely this is you rproblem
Nov 25, 2011 | Samsung RS265LABP Side by Side...
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
I have a singer inspiration4212 and I was sewing and a piece of materialwent down into the feed dogs and I had to tug a bit to get it out.Now my bobbin won't pick up the thread. I have taken the bobbin...
even if the needle is not bent, the needle could have a burr on the tip, I would try a new needle
clean under the needle plate & in the bobbin area for loose thread or lint
if the machine still does not work then it could be out of time
Aug 02, 2011 | Sewing Machines
Side by Side fridge stops cooling and the works again !
soiunds like the defrost timer is bad, Unless your highly mechanically inclined I would go ahead and call out the service repair company and tell them to be sure to bring allong a timer fo your unit. Hope this helps and good luck.
Jan 09, 2009 | Whirlpool ED2FHGX Side by Side...
Fridge not cooling 60 degrees
hi thanks for the question did you clean the coils at the back by the compressor if not clean the coils its very important try that thanks the appliance doc
Sep 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
